Crawlercreations 60-9 front axle and $$$$$$ build
Re: Crawlercreations 60-9 front axle build thread
Postby crawlercreations » Mon Feb 19, 2018 11:33 am
Jesus_man wrote:How long are your links and can you send me a picture of the frame mount? Looks very tucked up in there!!
I'll get you that info once I get a little more done.
Re: Crawlercreations 60-9 front axle build and install threa
Postby crawlercreations » Mon Feb 19, 2018 11:41 am
Productive weekend! Still going today. Might be driving it tomorrow! Gotta get a new front driveshaft but that is easy.
Currently about an inch high. Counting on coil settle to bring it to the right height.
Still have about 6" more droop but didn't want to lift it any higher for safety.
Gonna be cutting the front a little more but not too bad considering they're 40s.
Clearances are really tight. I had to sacrifice the hydro bumps for the right link placement. I've got shaft mounted bumps on their way. Cut the cross member off a bit for clearance even.
Postby Justin » Mon Feb 19, 2018 9:50 pm
Looks awesome! Bummer about the hydro bumps. Mine make the giant speed bumps in my neighborhood disappear, but I suspect your numbers are way better what I can get on radius arms.
Postby Dirtheadz » Tue Feb 20, 2018 7:05 am
Like it!!!
Dirtheadz
Postby landshark » Tue Feb 20, 2018 7:06 am
If you end up not wanting the fox bumps and cans iam interested
Postby crawlercreations » Tue Feb 20, 2018 7:20 am
landshark wrote:If you end up not wanting the fox bumps and cans iam interested
They're going on the rear when I build the fabricated housing, 35 spline 9" and rework the rear suspension while stretching it.
Postby landshark » Tue Feb 20, 2018 7:31 am
Cool
Postby crawlercreations » Tue Feb 20, 2018 10:46 am
Lower links are 37" eye to eye. Upper is 23" eye to eye. That put all my calculator numbers right where I wanted them and minimized my caster/ pinion angle change through cycle. Track bar is only 31". I would've liked longer but it wasn't happening.
Lower link frame mount.
Upper frame mount.
Axle track bar and upper mount.
Postby Jesus_man » Tue Feb 20, 2018 2:44 pm
Thanks! At first, it looked like your lower link mounts were internal of the frame. But I see now it was the upper link.
I am sure it'll work out wonderfully!!
Postby Strike2 » Tue Feb 20, 2018 8:14 pm
Looks awesome!
Once you stretch the rear wont the U/L links length change? Or is the 37” 23” you target length.
Strike2
Postby crawlercreations » Tue Feb 20, 2018 9:40 pm
Strike2 wrote:Looks awesome!
This is the front link lengths. They won't be touched when I stretch the rear.
Postby Strike2 » Wed Feb 21, 2018 7:50 am
oops Ok that make more sense I thought the rear U/L we kindof short, but that number fall right in line with my front upper link.
Strike2
Postby crawlercreations » Sat Feb 24, 2018 5:13 pm
I drove it today! Was waiting on limit straps, bump stops and grade 9 bolts. It all came in last night or this morning so I installed it all. It feels very soft and different to drive. I need different springs to get my ride height where I want it with preload. It flexes really well! The limit straps are perfect and allow just the right amount of travel. I've got an inch of coilover shaft still in the body at full limit and the driveshaft has about 1.5" left of droop before it would bind. I'm pretty ecstatic! I might be looking to do a snow bashing trip in it as soon as I get comfortable driving it on the street.
I'm still about .5" high on the suspension but it's close. Total lift is sitting just under 6" here on 40s. Once I get the right springs it'll be right about 5.5" of lift. 5" of coilover shaft at ride height.
42" under that back tire with a little more to go.
Even at this height I still fit in a normal garage with about 2" to spare!
Postby Strike2 » Sat Feb 24, 2018 8:11 pm
That is awesome!! Congrats on getting it on the road that is one bad ass flexing Bronco .
Strike2
Postby ZOSO » Sat Feb 24, 2018 8:11 pm
That looks awesome.
Postby Kinder » Sun Feb 25, 2018 8:18 am
It looks great, and you accomplished it in record time. If you go snow wheeling in a 33” tire friendly spot I’d like to get Willem’s bronco out on the trail and give his new setup a thrashing.
Postby crawlercreations » Sun Feb 25, 2018 1:49 pm
Kinder wrote:It looks great, and you accomplished it in record time. If you go snow wheeling in a 33” tire friendly spot I’d like to get Willem’s bronco out on the trail and give his new setup a thrashing.
I'll keep you updated. I'll be driving it all week to get used to it and see how the weather is going to be. I'm thinking Yankee Hill outside of Central city or the road we've gone on before off of fall river road heading up to Chinn's lake. Not sure about 33 friendly but it usually gets better with something bigger leading the way. Me on 40s followed by my uncle on 37s should pave the way for some 33s. Maybe even get someone else to join in on 35s?
Postby Kinder » Sun Feb 25, 2018 4:09 pm
Cool, he’s running lockers front & rear w/ a winch.
Postby ZOSO » Sun Feb 25, 2018 6:41 pm
Hmm a rig on 35's you say? I'm interested. I'd like to go play in the snow. If it's as soon as next weekend I am busy. but the following im in.
Postby Jesus_man » Mon Feb 26, 2018 8:31 am
That turned out amazing!! You have built an awesome rig!! How high is that wheel off the ground? Looks to be pretty near 40"!
I hope to get on the trail with you someday to watch this thing in action!
Postby crawlercreations » Mon Feb 26, 2018 9:43 am
Jesus_man wrote:That turned out amazing!! You have built an awesome rig!! How high is that wheel off the ground? Looks to be pretty near 40"!
The rear in that pitcure is 42" to the bottom. There was still a little more in it but it was dragging the other rear tire sideways so when I lowered it it would have been up against my lift so I stopped before it got too bad. It impressed me even!
Postby crawlercreations » Mon Mar 05, 2018 9:28 am
My coilover springs are much closer now. Still not exactly what I'm after but close. One more change and I think I'll have what I'm after. At least now I have a little preload on them and they're the right length. The front end is lighter than I expected!
Total lift on 40" tires is just under 5". Pretty good in my opinion!
Last edited by crawlercreations on Mon Mar 05, 2018 9:43 am, edited 1 time in total.
Postby Jesus_man » Mon Mar 05, 2018 9:35 am
Looks amazing!! A great achievement when you're running nearly a full body!
Postby crawlercreations » Mon Mar 05, 2018 9:51 am
Jesus_man wrote:Looks amazing!! A great achievement when you're running nearly a full body!
The narrow axles make packaging difficult. The front axle is 4" wider than stock(It's around 63" WMS to WMS) but all of that additional width is from the Cs out since the dana 60 stuff is so much bigger. That makes the housing the same width as the stock dana 44. Killed my hydro bump mounting but, honestly, I am highly impressed with the shaft bumps. They feel quite progressive and unnoticeable really. I haven't used them much but I have gone the speed limit over bumps and the front end soaks them up like they aren't there. Makes the coils and shocks in the rear feel really stiff. I hope the shaft bumps don't add a lot of stress to the shocks themselves. I have installed grade 9 bolts in every single position so bolt strength should not be an issue.
Postby Strike2 » Mon Mar 05, 2018 12:01 pm
What type of shaft bumps did you go with and can you post a picture?
Strike2
Postby crawlercreations » Mon Mar 05, 2018 1:34 pm
Strike2 wrote:What type of shaft bumps did you go with and can you post a picture?
They're Eibach shaft bumps sold by poly performance. Rated at 909 in.lbs. or something like that.
Postby Strike2 » Mon Mar 05, 2018 2:37 pm
Thanks for the picture, I may have to consider that route if I run out of axle room.
Strike2
Postby crawlercreations » Sun Apr 29, 2018 9:20 am
Figured I'd update this. I haven't done much else on the bronco yet but I've been collecting parts again. Still waiting on a couple important pieces to arrive. I've ordered and received 40 spline rear axle shafts and spool, Yukon load bolted 3rd for the rear, wilwood master cylinder, wilwood proportioning valve, line lock, corbeau seats, corbeau harnesses, different hood pins, and 16" Ori struts. I'm waiting on my new atlas transfer case, rci rock crawler fuel cell, and my 14" Ori struts to come in. As soon as I have those I'll install the 14" Oris up front, install the atlas, and stretch and install the new fabricated rear axle. I'm really hoping I never break again! The 40 spline axles are crazy big.
The atlas should be here this week or next. I ordered it almost 5 weeks ago. A couple local guys waited exactly 6 weeks for their's, recently. The 14" Oris are just waiting on a guy that's full of excuses to ship. Hopefully he gets them out Monday, as promised. The fuel cell should ship out soon, I hope. I've got another fuel cell I can use in the meantime.
I've also got a new (really old actually) hood that Keith is narrowing and painting for me. Fiberglass with the scoop.
I did extend the passenger wheel well to prepare for the stretch. Gotta do the driver's side still but I'll wait on that until I receive the right fuel cell.
16" Oris
Hood pins
Wilwood master
Corbeau seats
40 spline shafts (side by side with 35 spline!)
Next to 31 spline
Postby ZOSO » Sun Apr 29, 2018 10:26 am
Damn. I thought 31 next to 28 was crazy. Them some big axles.
Postby Jesus_man » Sun Apr 29, 2018 3:35 pm
Amazing stuff!! Can't wait to see it in it's stretched glory!
Return to Chit Chat
