www.ColoradoClassicBroncos.com - View topic - Brake pedal for Automatic Transmission
It is currently Thu Oct 31, 2024 10:42 pm
Reply to topic  [ 8 posts ]
Post Brake pedal for Automatic Transmission
Looking to swap out my Clutch and Brake pedal for the Brake pedal only...
I assume they are different, or can I just remove the Clutch Pedal and have the same thing?
If they're different, I'd rather have the Automatic instead of a chopped version...if ya know what I'm sayin'!?
Tue Mar 06, 2018 12:10 pm
Post Re: Brake pedal for Automatic Transmission
You can just pull the clutch pedal and leave the brake pedal. If my memory is right the ‘76 & ‘77 had larger brake pedals, but hard to find.
Tue Mar 06, 2018 12:27 pm
I pulled the clutch pedal when I converted mine. I also saved all the clutch linkage parts, bell housing, and flywheel and gave them to one of the members that needed them for a project he was working on.
Mark.
Tue Mar 06, 2018 12:56 pm
OK Cool!
I'll just ditch the clutch pedal then!
Thank You!
Tue Mar 06, 2018 2:29 pm
Kirk is correct-- in 76-77 they changed the brake pedal assembly for automatics for the power brakes to a wider pedal-- you'd be looking at close to $200 to buy one online (and I know how cheap you are!!). I don't think it is worth it unless you came across one (I also know you are a craigslist mastermind)!
Tue Mar 06, 2018 2:51 pm
Tue Mar 06, 2018 5:13 pm
Put a spacer in where the clutch pedal comes out.
Tue Mar 06, 2018 9:18 pm
Tue Mar 06, 2018 10:17 pm
Users browsing this forum: No registered users and 25 guests
32,736,087 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
