It is currently Tue Dec 03, 2024 1:23 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 76, 77, 78, 79, 80, 81, 82 ... 89  Next
72 Bronco Sport, 5.8 EFI, NV3550
Wed Mar 07, 2018 10:20 pm
This followed me home today.
Sat Mar 10, 2018 9:31 pm
Yes!
Sun Mar 11, 2018 8:07 am
Nice! What are your plans for the new ride?
Sun Mar 11, 2018 8:13 am
Sun Mar 11, 2018 7:50 pm
Not sure what I’m going to do with only 3 wheels, but I got these today!
15x8.5” with 3.5” Backspacing. (If I’m measuring it right?)
Looking for #4...Anyone?
Tue Mar 13, 2018 9:16 pm
Finally ordered my gears, axles, and rear arb. Now to find time to start the install. Chris I'll have the front 4.10's pulled out for you soon.
Tue Mar 20, 2018 8:39 am
Tue Mar 20, 2018 8:46 am
So I did this today...
I took the old leaf springs that were on the truck when I bought it and disassembled them. Then I took the old original Bronco Leafs that Kirk gave me that were totally spent (like they all are!) and disassemble them as well.
What I came up with is a 10 pack 3.5” Lift that I’ve been panhandling for!
Wed Mar 21, 2018 5:35 pm
^ very interesting, you’ll need to do some measurements once they are on the truck and post up.
Wed Mar 21, 2018 6:39 pm
Another package has showed up. It is matching gearsets. 5.13's here we come. Today should be the rear arb and 31spline axles.
Thu Mar 22, 2018 6:40 am
Thu Mar 22, 2018 8:40 am
Let the Beatings BEGIN!!!!
engine swap
3 speed manual to C4
3 on the tree to Automatic tilt Column Swap
and Add Power Steering with 4x4x2 box
I even sold the manual column, getting ready to ship it!
Sat Mar 24, 2018 12:28 am
Got the Front and Rear Driveshafts out along with the skid plate under the Dana 20...
Never seen so much oil and dirt Ever!!!
Sat Mar 24, 2018 9:26 pm
Stacks of parts I need time to install. Not pictured is the passenger seat and seat belt. Along with a window. New jgz door panels and quarter panels.
Sun Mar 25, 2018 9:08 am
I removed the exhaust manifolds and exhaust/ muffler
I got the Starter out,
The clutch parts on the engine bay side out,
Then I removed the clutch and brake pedals.
I made the single brake by removing the clutch....reinstalled it, and then I see this on CL!!!
Sun Mar 25, 2018 10:27 pm
Well, not so much what I did to my bronco today, but what it did to me!!!
Mon Mar 26, 2018 9:09 pm
You broke it? Or you talking bodily harm?
Tue Mar 27, 2018 9:38 am
Thu Mar 29, 2018 5:21 pm
Thu Mar 29, 2018 6:06 pm
Boost me! Still need to adjust my pedal.
Mon Apr 02, 2018 2:13 pm
That'll be awesome! I keep thinking I should do this...but so much else needs done.
Mon Apr 02, 2018 2:38 pm
Mon Apr 02, 2018 8:57 pm
Looks good John. Curious to see what you think of the pedal feel. Mine is real soft with nearly zero feedback.
Tue Apr 03, 2018 7:24 am
Well, I do like the offset. I still have plenty of room for a compressor and maybe a small tool kit. I had to whittle about an inch off the threaded end of the input rod and cut some new threads for it. Rob (Zoso) forewarned me on that. I also had to trim the end for the brake light switch. It was so tight the brake lights were constantly on. But the one thing I don’t like is the open hole where the old master cylinder was. I’m on the hunt for a boot or bellows to eventually deal with that. Gotta order that rebuild kit for the booster. Got the kiss of death from Chris’s leaking out the weep hole.
Tue Apr 03, 2018 5:27 pm
I’ve come to the conclusion everything leaks.
Wed Apr 04, 2018 4:42 pm
Wed Apr 04, 2018 4:55 pm
I’ll probably break down and Order the rebuild seal kit, have a few things ahead of it.
Wed Apr 04, 2018 5:11 pm
I got my automatic tilt column installed today, tomorrow I will uninstall it because of my little screw up, can you guess what I forgot?
(It’s not the wiring...)
Wed Apr 04, 2018 8:06 pm
Finally got my ‘75 plates linked to mine.
Fri Apr 13, 2018 10:57 am
33,207,270 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
