ZOSO wrote:How has that clutch fan worked out for ya this year?
kinder wrote:Is there anyway to find out how much contact is occurring? If it's tenths off mm or less than a mm maybe you could machine the the engagement arm or bearing contact surface. Not that I don't like cutting and welding stressed components, but I wonder if the engagement arm is strengthened by one of many processes.
kinder wrote:Just be glad you don't have a stupid internal slave cylinder to deal with, the one I replaced is already leaking.
Gunnibronco wrote:What brand? Just so I can avoid. I'm buying one soon & that is one of my fears going to the ZF.
Gunnibronco wrote:Thanks,
And build a couple extra external slave cylinders while you are at it. I bet you could sell a few.
landshark wrote:you can pull entire external slave setups off zf-5's behind 460s. Its all one unit and comes with an integrated mount retainer for the external bracket.
Rox Crusher wrote:Is that another fine installation of expensive parts by the PO ?
landshark wrote:Rox Crusher wrote:Makes me want to pull the front and inspect that too..
Users browsing this forum: Google [Bot] and 5 guests
