Backcountryrenegade
Joined: Fri May 15, 2015 10:28 pm Posts: 41 Location: Elizabeth, CO
Need a motor!
OK- Dana says my 302 in my 75 is done. I need a motor. 75, 302, C4. I don't have the garage tools or space, much less the experience to swap a motor so looking for ideas. I don't have a coyote budget- more like a coors light budget. Truck is a driver, camping rig, occasional tower. Open to all options- would like to see if I can afford a 351 or 5.0 swap but beggars can't be choosers. Thanks!
Tue Apr 17, 2018 5:16 pm |
cravenbronco
Re: Need a motor!
I'll help pull it out and install the new one.
Tue Apr 17, 2018 6:30 pm |
Backcountryrenegade
Re: Need a motor!
Sweet- thank you. I need to find a motor. Where are you located?
Tue Apr 17, 2018 6:46 pm |
plumbdoctor
Re: Need a motor!
Was in contact with you on FB? I have the 5.0 if you are the right guy???
Tue Apr 17, 2018 6:52 pm |
cravenbronco
Re: Need a motor!
Tue Apr 17, 2018 7:30 pm |
Re: Need a motor!
Looks like there are now two of you needing budget motor swaps and it sounds like there may be 2 5.0 motors in the club available for inexpensive purchases. Sounds like it could be the making of a fun engine swap club weekend.
I know there are a few of us leaving for Baja Mexico in a few weeks so depending on urgency, I’d be happy to help out after mid May.
If we could get a location, a couple trailers (if not currently driveable) and about 6-8 guys, we could get both done in a weekend.
Tue Apr 17, 2018 8:31 pm |
cravenbronco
Re: Need a motor!
Tue Apr 17, 2018 9:26 pm |
Bronco1294
Re: Need a motor!
Have lines on 2 motors. 138k 5.0 1998 explorer and a fresh rebuild 93 cobra with e303 cam. I want to have everything there so as not to waste anybdy’s time- what else will I need to get? Fuel pump? Lines?
Sat Apr 21, 2018 10:45 pm |
Backcountryrenegade
Re: Need a motor!
Hey all! Thanks again for the offer to help swap these motors! I am picking up a 351W tomorrow morning early in Loveland. I'd like to see about coordinating an install with whomever is able to help. This weekend would be ideal but it's kind of short notice so if that's not possible I completely understand. We need a location with tools, cherry picker, etc. and hands to do the wrenching. Is anybody up for this weekend, and does anybody have a location? I've never done this so I'm anxious to learn! Thanks!!!
My number is 303-929-6717
I've got a new tank and fitech on order- we'd be pulling the 302 out, swapping over whatever is necessary (Front Dress?) and dropping the 351 in. I'll be doing the Fitech/tank when it shows. That I think I can handle. If anybody has a shopping list of things you know I'll need to bring please shout out- don't want to waste anybody's time not being prepared! Thanks!
Incidentally I've got a 1 inch Body Lift to put on it as well- is that do-able at the same time? I'm guessing not but I've never done one before.
Wed Apr 25, 2018 4:15 pm |
cravenbronco
Re: Need a motor!
Wed Apr 25, 2018 5:31 pm |
Backcountryrenegade
Re: Need a motor!
Wed Apr 25, 2018 7:55 pm |
cravenbronco
Re: Need a motor!
I put one Jack under each rocker with 2x4 between Jack and rocker. Worked out well. I put Jack stand's in front and rear for a safety but didn't need them. Didn't wobble and lined back up when I set it back down. Hardest part were the original bolt's holding it on.
Wed Apr 25, 2018 8:00 pm |
Backcountryrenegade
Re: Need a motor!
Wed Apr 25, 2018 8:02 pm |
Re: Need a motor!
I’m happy to help as well but will be getting ready to go to Baja this weekend (as is a number of us). My guess is you’d get a lot more help after the middle of May.
Also- are you planning on trailering your rig to wherever this swap happens? Changing to a 351W requires a number of additional things all depending on what upgrades you’re going with. It most likely will not be driveable in a weekend.
Wed Apr 25, 2018 8:11 pm |
Backcountryrenegade
Re: Need a motor!
Wed Apr 25, 2018 8:21 pm |
