I was taking off all the front dress v-belt set up on my engine to get it ready for the serpentine swap and there is a bolt that had been previously broken off near one of the water ports.
I was able to use a small drill bit at first then a larger drill bit without problem. Then I finally got to use my handy-dandy easy out .... snap!
Now what!!!???
I have tried using tiny drill bit’s around the side of the easy out breaking three of them. I have tried using a couple of small Dremel grinders and I’ve made a tiny bit of headway, and I have tried using small chisels to hammer and break it up, all to no avail.
Any help would be appreciated.
