Throttle Body Position
Postby Strike2 » Thu May 24, 2018 12:51 pm
I have a 96 Explorer EFI set up and was checking clearance for the throttle body and the hood will not close in the OEM position (pic1) is there any reason that I shouldn't rotate it 180 degrees? (pic 2).
Strike2
Re: Throttle Body Position
Postby Viperwolf1 » Thu May 24, 2018 1:04 pm
You can rotate it.
Postby Strike2 » Thu May 24, 2018 1:09 pm
Great news! Thanks for the reply
Strike2
Postby D&D72 » Fri May 25, 2018 12:23 am
I took that EGR stuff off of mine and ran the throttle body straight off the riser/plenum.
D&D72
Postby Strike2 » Fri May 25, 2018 5:26 am
D&D72 wrote:I took that EGR stuff off of mine and ran the throttle body straight off the riser/plenum.
Well that looks much cleaner, Thanks for the letting me know I think that set up will fit much better thumbs up
Strike2
Postby mickphatmac » Fri May 25, 2018 8:12 am
I have a non-egr lower inake that you can have along with the upper intake it you want it?
I need an aux tank skid plate???
Postby Strike2 » Fri May 25, 2018 8:53 am
mickphatmac wrote:I have a non-egr lower inake that you can have along with the upper intake it you want it?
Is a non-egr lower any benefit to the 96 I have?? I think I might have a aux tank skid plate or main skid plate its been awhile since I looked at my pile . Ill text you later once I get home.
Strike2
Postby landshark » Fri May 25, 2018 11:23 am
The one with an EGR has a hole in the center of the lower that you should plug. I tapped and screwed a pipe plug in it. The ones without an EGR don’t have the hole.
Postby mickphatmac » Fri May 25, 2018 12:07 pm
My lower intake has NO HOLE to plug.
I don't know about the EGR from beans!?!?
...but definitely 1 more electronic thingy you can DELETE!
