speedometer woes.
speedometer woes.
Postby ZOSO » Thu May 24, 2018 3:33 pm
With my recent regear my speedometer is now fast. By about 18%. So doing the math I's need a 24 tooth driven gear. Well they only make a 21 max. Current is 20teeth. Not sure what the drive gear tooth count is. Any ideas on how to correct it with out buying a new digital cluster?
Re: speedometer woes.
Postby Digger » Fri May 25, 2018 7:40 am
Bigger tires?
Postby landshark » Fri May 25, 2018 8:07 am
Phone GPS/Speedo?
Postby Viperwolf1 » Fri May 25, 2018 8:32 am
Replace the speedo drive gear on the output shaft with a 6 tooth version.
Postby ZOSO » Fri May 25, 2018 2:30 pm
Viperwolf1 wrote:Replace the speedo drive gear on the output shaft with a 6 tooth version.
Have one laying around?
Postby Viperwolf1 » Fri May 25, 2018 2:31 pm
Probably do.
Postby ZOSO » Fri May 25, 2018 2:32 pm
I'll trade ya if you do.
Postby Viperwolf1 » Fri May 25, 2018 2:47 pm
Let's make sure you have a 7 first. What color is the gear?
Postby ZOSO » Sat May 26, 2018 7:55 am
Viperwolf1 wrote:Let's make sure you have a 7 first. What color is the gear?
Blue
Postby Viperwolf1 » Sat May 26, 2018 8:30 am
Blue
Got a green 6 tooth one. Come get it while it's hot, out.Image
Postby ZOSO » Sat May 26, 2018 12:33 pm
Phil I'll give you a call Monday and can run up then. Gotta stick around to this side of town as I have the electronic leash until then.
