Looking for a referral: wiring work
Postby laffycaffi » Tue May 22, 2018 11:17 am
I'm looking for a mechanic who is honest and reasonably priced who can fix some wiring issues I'm having: turn signals don't work, brake lights only work on occasion. I just am not wired (pun intended) for that kind of work myself. Any referrals are appreciated. I'm in Centennial (near Aurora). Thanks!
laffycaffi
Re: Looking for a referral: wiring work
Postby Viperwolf1 » Tue May 22, 2018 2:56 pm
Sounds like a simple turn signal switch replacement.
Postby Kinder » Tue May 22, 2018 7:30 pm
You’re just up the street from me, so I can lend a hand with troubleshooting. I’ve fixed my share of turn signal / brake light problems. My schedule is super tight but I can usually spare an hour or two Thursday afternoons. Just let me know.
Postby laffycaffi » Sun Jun 17, 2018 1:26 pm
So I'm just going for it, replaced the turn signal switch. Here are my results: brakes worked for a second. But now they don't. Hazard lights now work for the first time ever. Front and back! Turn signals do not. Horn no longer works.
And I get this when the battery is connected. See attachment. So frustrating. Any thoughts?
Still looking for a referral. I hate working on electronics
laffycaffi
Postby laffycaffi » Sun Jun 17, 2018 1:29 pm
laffycaffi
Postby cpldavis37 » Fri Jun 22, 2018 7:58 pm
Have you changed the flashers? Also check out the brake switch.
TJ
F. Scott Fitzgerald
cpldavis37
Postby laffycaffi » Fri Jun 29, 2018 5:11 am
I installed a new turn signal switch and it solved my problems. We can now conclude this episode of Mark needs help. Thanks!
laffycaffi
