It is currently Mon Jun 03, 2024 10:21 pm
Reply to topic  [ 324 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
 75 Bronco Build
Post Re: 75 Bronco Build
D/F 998lbs P/F 1032lbs
25.8% 26.3%
D/R 966lbs P/R 882lbs
24.9% 22.6%[/quote]
Those weights sound lighter than I would expect! Makes my coilover spring weights sound more correct. I was thinking I was light on the springs but there isn't a whole lot of sprung weight on a Bronco I guess! I am at 100 over 200 on my coil over springs. That gives me 5" of shock shaft exposed on about 4.5" of lift but almost no pre-load on the springs. I think I will end up with 100 over 150 once I am all done with my suspension work. Just as kind of an FYI for your starting point.[/quote]
Crawlercreations,
I was pleasantly surprised with the weight myself I was thinking more along the 4500 but I'll be happy if it stays under 4K, I weighed it 4 times and got an average. I'll be running 12" 2.5 Kings custom shimmed with 12"/200 uppers and 14"/300 lowers to start out with and see how that turns out??
Mon Mar 19, 2018 10:41 am
Mon Mar 19, 2018 11:18 am
I'm pretty close to crawlers spring rates.
Thu Mar 22, 2018 8:00 pm
A small milestone on the Bronco build this weekend, I was able to get the front shocks mounted and cycled. Now to move on to the rear with some minor metal trimming.
Mon Apr 09, 2018 12:37 pm
Nice keep the pictures coming. Can't wait to see this thing when you are all done with it
Mon Apr 09, 2018 2:52 pm
Tue Apr 10, 2018 7:42 am
I think I have the rear C/O mounts figured out I just need to tac the upper mounts, duplicate to the passenger side and cycle the axles to check tire/frame clearance. I also need one more stick of tubing as I forgot about adding a vertical brace for the rear shock mounts banghead
Cutting the wheel wells was just a WAG but I got the same angle as the front C/O's. I'm hoping to have enough room to add a 40" bench seat.
Wed Apr 11, 2018 9:38 am
That looks killer! I am sure this will perform well! Any type of boot that can be added there to keep dust and other elements out?
Wed Apr 11, 2018 10:27 am
Thanks Jesusman.
Yes once I check clearances I should be able to bend up some sheet metal to cover it up to the top hat, and using a round gasket it should be 100 sealed with no coil springs showing from the inside.
Wed Apr 11, 2018 11:08 am
Not much progress in the last 3 weeks, as the wife and I traveled to Italy. Lots to see and plenty of good food/wine during our travels I can say it was a good break from the garage. Just before we left I was able to test fit a 40" rear bench seat and to my surprise it fits really well between the rear coils. I'm trying to get my garage mojo back but can honestly say that trip kicked my butt lots and lots of walking.
Mon May 14, 2018 2:19 pm
Cinque terre and Rome! Where else? Tuscany? We didn't get to spend much time in Italy, but 4 days in Rome, and probably 12 driving from Florence, down thru Tuscany, Piza, and back into Florence. Fun place!!
Mon May 14, 2018 4:45 pm
Tue May 15, 2018 6:40 am
Tue May 15, 2018 2:54 pm
With the 96 Explorer serp parts installed I was surprised that the shock hoop bar actually cleared the components with little modification.
The power steering reservoir was too tall IMO and I had plans to use the large ford power stroke version but I think its a little too large to fit so for now I'm using a 97 Grand Marquis. Fitting the coil packs also required some "trimming" of the hood crossbar but I now have 3/8" clearance with the hood shut.
My next hurdle was the radiator, when installing the engine cage I used the 75 radiator for mock up, WTF was I thinking the tabs are all wrong for the 94-4.0 radiator and the tube is not bent correctly to mount the new radiator, So I will have to re-design it which sucks because the grill mount is almost perfect oh well. While changing the bar I might also be channeling the passenger side frame 1.5" in order to center the fan blade to the radiator since this will forever bug me. The only highlight is that the wife works this weekend so I get 2 full days of "Garage Time"
Wed May 30, 2018 9:51 am
Replacing the front engine bar wasn't as a bad as I thought, mocked up some scrap bars for reference points and then started cutting. The new front bar is cleaner looking and the 4.0 radiator fits perfect with plenty of side clearance. I bent some lower radiator mounts fabricated some tab mounts for the 4.0 fan shroud and it all fits using the OEM mounting points. While at the JY I found this air box off a 97 Benz that looked to have the 2-ports in the correct location and was able to fit it in the battery spot using all the Benz tabs including the lower rubber mount. My plan for the battery was to mount somewhere inside the bronco but found that I have a open spot on the front driver side that would work, both air box and battery are 7" up above the tire at full lock which will be fine since I only have 6" of up travel. With only a 1" body lift everything clears the hood by 1/2"+ except the coil packs they actually just touch the hood cross bar so I channeled 1" out.
My next step is work welding in all 4 fender skins and then I believe I'm ready to tear is all apart for cleaning/welding the frame for final install.
Mon Jun 04, 2018 9:57 am
That benz box works amazingly well. Are you going to reuse the factory benz air filter? Are you going route the intake somewhere else? Nice fresh air there, but very easy to ingest water. Nice rework of the cross brace.
Mon Jun 04, 2018 10:05 am
Mon Jun 04, 2018 11:47 am
Gotcha and I think that's a a good plan with some ducting. But really, there are a handful of CO trails that have some deep water crossings. Well, at least they used to be when CO got snow... The gulches West co 'Springs comes to mind. Madeno Pass is another.
Mon Jun 04, 2018 1:24 pm
This weekends marks a year that I brought the Bronco home, needless to say I may have fibbed to the wife on how long it would take me to get it on the road although in my defense I wasn't planning on a full link suspension so that along with trouble getting it started and keeping it running may have set me back 3 months (not that I'll have it done in 3 months)
This weekend I had two friends stop by to give an extra hand holding the flares while I tacked them in place.
Mon Jun 11, 2018 9:41 am
Tube flares are fully welded with all the welds ground down, so I just need to run a small skim of body filler on the fender side and then I think I'm ready to remove the body.
Mon Jun 18, 2018 2:25 pm
Those look great !
Mon Jun 18, 2018 6:57 pm
Mon Jun 18, 2018 8:25 pm
Very unique and nicely done!
Sun Jun 24, 2018 6:02 am
In a build full of very cool, super highly functional stuff, this may be the first idea I am stealing for mine. There are others, but this may be the first I actually fab and install
Sun Jun 24, 2018 6:48 am
Sun Jun 24, 2018 7:07 pm
I finished seaming and spraying etching primer on the bare steel flares.
Mon Jul 02, 2018 8:55 am
Worked on making a safari top with removable side panels, the side panels are held in place with just two bolts on the top and pinned on the bottom using 3 of the oem holes. My plan is to not install the glass but maybe have some Plexiglas inserts to carry just incase of rain and then have a canvas rear hatch made up. I think the safari top will be a nice touch painted blue and still look like bronco with a more open air feel.
Mon Jul 02, 2018 9:28 am
Sunday I finished tacking the top of the cage and then removed the suspension/axles dropped the frame on some carts and then removed the cage. Man a 2 car garage just isn't big enough!
Mon Jul 02, 2018 9:36 am
I wish I could work even half as fast as you do. If I could, I'd be done by now.
Mon Jul 02, 2018 10:34 am
[quote="phyler"]I wish I could work even half as fast as you do. If I could, I'd be done by now.
I'll let you in on a little secret, listen to 105.5 the Colorado Sound and drink a 16oz or 20oz RedBull and don't even mess with the baby 8.4oz cans! icon biggin
Mon Jul 02, 2018 11:59 am
29,742,415 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
