Disc brakes for 9” - explorer if possible.
Postby landshark » Wed Jun 20, 2018 7:15 am
Looking to convert a ford 9” big bearing rear end to disc brakes, probably would prefer the explorer setup. Do not need ebrakes.
Re: Disc brakes for 9” - explorer if possible.
Postby BroncoRaider » Wed Jun 20, 2018 8:49 am
If only there s a member in Greeley that has a pseudo Explorer graveyard....
BroncoRaider
Postby Viperwolf1 » Wed Jun 20, 2018 5:30 pm
Unfortunately they don't bolt on to the HD axle. They can be made to fit though.
Postby landshark » Wed Jun 20, 2018 8:06 pm
Viperwolf1 wrote:Unfortunately they don't bolt on to the HD axle. They can be made to fit though.
i wil do some reasearch, i know you ahve to re-drill the rotors correct?
Postby phyler » Wed Jun 20, 2018 8:13 pm
Yes, or you can order new ones from Currie. $80/rotor from them. I've got everything but the rotors and spacers. I have the 9" with Torino ends so it's bolt on for me. The spacers make up for the difference in the backing plate.
CCB Admin
Postby Viperwolf1 » Wed Jun 20, 2018 8:15 pm
Yes and the axle tube ends have the torino bolt pattern. That is the same as the 74-75 medium duty axle.
You can buy a kit that has everything already converted which is the way I would go.
Postby landshark » Wed Jun 20, 2018 8:16 pm
Viperwolf1 wrote:Yes and the axle tube ends have the torino bolt pattern. That is the same as the 74-75 medium duty axle.
ok, i am trying to keep it easy to replace but i think most of the aftermarket kits will have stock parts amoung the custom ones..
Postby ZOSO » Thu Jun 21, 2018 5:11 am
Who offers said kit? My drums are in need of work and the oddball medium duty stuff is a pain to get locally.
Postby phyler » Thu Jun 21, 2018 6:15 am
If you have the medium duty rear end already, just strip everything off an 8.8. Then buy the rest of the pieces from Currie. You'll need the spacers, rotors and e-brake cables. You can either get the brake hoses from them or source your own from Napa. I'm getting ready to do this. I'll try to document it since I haven't found a good, complete write up.
CCB Admin
Postby cpldavis37 » Fri Jun 22, 2018 7:49 pm
I'll be waiting for the write up. icon biggin
TJ
F. Scott Fitzgerald
cpldavis37
Postby plumbdoctor » Sun Jun 24, 2018 7:07 pm
Get. It all from pull and pay, new lines from Currie and spacer rings....cheapest route. Torino ends make it easy...key holing to fit larger is not too hard either
plumbdoctor
Return to Bronco Parts Wanted
