Viperwolf1 wrote:Unfortunately they don't bolt on to the HD axle. They can be made to fit though.
Yes, or you can order new ones from Currie. $80/rotor from them. I've got everything but the rotors and spacers. I have the 9" with Torino ends so it's bolt on for me. The spacers make up for the difference in the backing plate.landshark wrote:Viperwolf1 wrote:Unfortunately they don't bolt on to the HD axle. They can be made to fit though.
i wil do some reasearch, i know you ahve to re-drill the rotors correct?
Viperwolf1 wrote:Yes and the axle tube ends have the torino bolt pattern. That is the same as the 74-75 medium duty axle.
You can buy a kit that has everything already converted which is the way I would go.
If you have the medium duty rear end already, just strip everything off an 8.8. Then buy the rest of the pieces from Currie. You'll need the spacers, rotors and e-brake cables. You can either get the brake hoses from them or source your own from Napa. I'm getting ready to do this. I'll try to document it since I haven't found a good, complete write up.ZOSO wrote:Viperwolf1 wrote:Yes and the axle tube ends have the torino bolt pattern. That is the same as the 74-75 medium duty axle.
Who offers said kit? My drums are in need of work and the oddball medium duty stuff is a pain to get locally.
