302 removal
Re: 302 removal
Postby crawlercreations » Wed Jun 20, 2018 8:16 pm
Backcountryrenegade wrote:Ok what am I missing? These brackets don’t line up with the adapter for the alternator. I figured out the power steering relocation but the alternator not so much. ImageImage
Your alternator bracket is the oddball bracket that was used with a power steering pump above it. Common on early power steering conversions. To make the adapter work you need a set of stock alternator brackets.
Re: 302 removal
Postby Backcountryrenegade » Wed Jun 20, 2018 8:18 pm
It’s stamped Ford? Interesting. Mine is a 75- thought it came with power steering?
Will that change the belt I use?
Backcountryrenegade
Re: 302 removal
Postby Viperwolf1 » Wed Jun 20, 2018 8:35 pm
Thermactor pump not ps pump.
Re: 302 removal
Postby Kinder » Thu Jun 21, 2018 6:24 am
I may have a old stock alternator bracket setup, I’ll look when I get home.
Re: 302 removal
Postby Backcountryrenegade » Mon Jun 25, 2018 8:53 pm
Anybody have thoughts on changing out the torque converter? What’s a good one to use? Mostly driver, towing some.
Backcountryrenegade
Re: 302 removal
Postby Viperwolf1 » Mon Jun 25, 2018 9:19 pm
Stock converter would be fine with the torque of a 351.
Re: 302 removal
Postby Backcountryrenegade » Tue Jun 26, 2018 7:57 pm
Crank moved when I bought motor. Been inside sitting for a month. Went to turn crank- won’t budge. No plugs installed. WTH??
Backcountryrenegade
Re: 302 removal
Postby Backcountryrenegade » Tue Jun 26, 2018 8:47 pm
Got it to move- panic attack there.
Backcountryrenegade
Previous
