I bought the front dress (serpentine) for my OLD engine off of an Explorer, How do I know if it's Standard or Reverse rotation...and does that effect anything???
What's the purpose?
mickphatmac wrote:I’ll check the water pump for markings but going with Reverse Rotation as consensus...
ThankYou!!!
ZOSO wrote:mickphatmac wrote:I’ll check the water pump for markings but going with Reverse Rotation as consensus...
ThankYou!!!
All explorer is reverse rotation. I don't believe you can get a standard rotation for the explorer.
Mitche11 wrote:It does matter. Did you happen to get the water pump when you got the explorer SERP setup? If you did, just take the part number into the part store and get the same one. As far as I know, the SERP routing didn’t change from 96-01, and they all ran in the opposite direction of the v-belt water pumps.
V-8 explorer serp water pumps and timing covers are identifiable because they don’t have a hole or mounting place for a mechanical fuel pump in them.Here’s a pic of a V-8 Explorer timing cover and w-pump off of a 2001.
