351 install
351 install
Postby Backcountryrenegade » Sat Jul 14, 2018 2:45 pm
I’m blanking but don’t some of you guys live in franktown ish? I’m trying to install my 351 alone and could use some extra hands if anybody is around. Thanks!
Backcountryrenegade
Re: 351 install
Postby Backcountryrenegade » Sat Jul 14, 2018 5:40 pm
Update- got it about 90% in. Can’t seem to get it the last half a inch back. It the torque converter that I can tell. Any ideas?
Also- if anybody knows the size of the bolts for the bell housing and which hole they go in I’d appreciate it! Smart guy here can’t remember which bolts go in which holes!
Backcountryrenegade
Re: 351 install
Postby Rox Crusher » Sat Jul 14, 2018 5:49 pm
When you put the torque converter in you should have felt / heard 3 pronounced spots before it seats.
Re: 351 install
Postby Backcountryrenegade » Sun Jul 15, 2018 12:39 pm
Did. It went all the way in. Just can’t get the motor back.
Backcountryrenegade
Re: 351 install
Postby horseplay » Sun Jul 15, 2018 1:39 pm
you might want to check the end of the crank shaft in case it has a pilot bearing in it not allowing the converter to seat in the crank.
horseplay
Re: 351 install
Postby Backcountryrenegade » Sun Jul 15, 2018 3:54 pm
So damn close...Image
Backcountryrenegade
Re: 351 install
Postby Viperwolf1 » Sun Jul 15, 2018 9:16 pm
Something not right there. Don't try to force it together with the bolts. You can break an expensive trans pump. Either converter is not all in or something else. What flexplate is it? C6 flexplate is different.
Re: 351 install
Postby Backcountryrenegade » Tue Jul 17, 2018 12:53 pm
It’s a 28oz flex plate. It was a bit hung up on the torque converter. I just need extra hands at this point, somebody who’s done this.
Backcountryrenegade
