Project Downward Spiral
Re: Project Downward Spiral
Postby Eck » Fri Jul 13, 2018 8:50 pm
I used the Escape box and it fit perfectly in the center. I will say that I redid my dash so the heater controls aren’t in the same place.
Postby D&D72 » Sat Jul 14, 2018 12:00 am
I did the same as Eck. Got a cardboard template if you want it.
D&D72
Postby Jesus_man » Sat Jul 14, 2018 6:12 am
A sound deadening mat would be good to add if it's easier to install now. Sure would go a long way into making these old steeds more quite!
I really need to figure out a way to mount my computer better. Interested to see what you come up with.
Postby landshark » Sat Jul 14, 2018 7:02 am
I would be careful welding with that stock insulation in there. It will easily catch fire and so will the wiring. At the very least try to stuff some fiberglass welding blanket over it but that stuff likes to burn.
Can’t help with the computer location [emoji51]
Postby phyler » Sat Jul 14, 2018 7:21 am
D&D72 wrote:I did the same as Eck. Got a cardboard template if you want it.
I'll keep that in mind for when I go to do that. Thanks!
CCB Admin
Postby phyler » Sat Jul 14, 2018 7:25 am
landshark wrote:I would be careful welding with that stock insulation in there. It will easily catch fire and so will the wiring. At the very least try to stuff some fiberglass welding blanket over it but that stuff likes to burn.
Yeah, I was thinking of ordering something that I could cut and stick to the cowl prior to welding it. No chance of getting it back in there without removing everything from under the dash if I don't.
I've watched that stuff smolder after a spark hit it. Not what I want. The wires are far enough away that I'm not concerned seeing as it is just spot welds.
CCB Admin
Postby Mitche11 » Tue Jul 31, 2018 10:37 pm
Bronco Hut sold me an aluminum piece shaped to hold my EEC. I mounted my computer under the cowl at the top of the diagonal sloping part on on the passenger side. I just used screws to attach the panel, and the insulation kept everything nice and snug. Simple and effective.
72 Bronco Sport, 5.8 EFI, NV3550
Mitche11
Postby Jesus_man » Wed Aug 01, 2018 5:15 am
Do you have a picture of this device?
Postby phyler » Wed Aug 01, 2018 6:25 am
Mitche11 wrote:Bronco Hut sold me an aluminum piece shaped to hold my EEC. I mounted my computer under the cowl at the top of the diagonal sloping part on on the passenger side. I just used screws to attach the panel, and the insulation kept everything nice and snug. Simple and effective.
Would love a pic. I think in my car, I just need to move one of the heater control cables in order to make the Escape box fit. I'll do that when I rebuild the heater box.
CCB Admin
Postby D&D72 » Mon Aug 06, 2018 10:47 pm
I didn't have to move anything for my escape box.....
D&D72
Postby phyler » Mon Aug 27, 2018 9:26 am
Well, been cranking on this as much as time will allow. Work has been nuts so I've been having to do things only on weekends. Got the cowl replaced finally!
My only concern right now is that the paint I got from Painter's Supply is a bit more orange than my existing paint. I will need to find a paint store that will help me match the paint better before I paint the exterior pieces. Anyone have a good paint store on the north end of Denver?
CCB Admin
Postby Jesus_man » Mon Aug 27, 2018 9:35 am
Looks great!!
Postby Strike2 » Mon Aug 27, 2018 1:27 pm
Hey Adam,
The paint job looks great nice work!
Matching paint is tough are you able to roll the cab out in the sunlight vs. florescent garage light to see if the paint tone changes? I use Auto Paint Supply for my paint its a small locally owned store at 5911 Washington Street Denver Co 80216 (303-292-4833) both Ted and Emo are easy to talk to and will answer any questions you have, they really helped me out when I started out painting.
Strike2
Postby phyler » Mon Aug 27, 2018 1:48 pm
Strike2 wrote:Hey Adam,
Thanks. I haven't. It doesn't help that I'm color blind and it's hard for me to see shades at times. I haven't rolled it out yet (but I did start it yesterday) so I'll see what that looks like. I see this issue with most Hot Ginger Metallic paint. It almost always has a different tinge. D&D72 and I were talking about it at the last breakfast.
Thanks for the reference to Auto Paint Supply!
CCB Admin
Postby Lobobronco » Mon Aug 27, 2018 6:36 pm
Hey Adam,
Looks great! And from another color blind guy to another....as long as it looks good to us...we’ll never know and it is our word vs. theirs:)!
Well done!
Matt
Lobobronco
Postby D&D72 » Fri Aug 31, 2018 2:43 pm
Fine job!
D&D72
Postby phyler » Tue Sep 11, 2018 7:17 pm
Family pitched in on this for my birthday:
This is the Bestop seat so I'll have to make the rear bracket but it came with the front ones. Just have to drill a hole and weld a nut on the bottom of the bed and one hole in the wheel well (if I remember correctly, Tom's has a great video on the install).
This will be loads safer than the stock seat for my kids. Now I just have to try and see if I can pay Digger to help me make one of his cages versus buying the one from Tom's. :) Oh, and convince myself that it's ok to sell the stock Ginger rear seat that I have cause storing just to store it doesn't sound like a good idea when I apply rational thought.
CCB Admin
Postby Strike2 » Tue Sep 11, 2018 8:24 pm
That’s a nice looking rear seat, Happy Birthday !
Strike2
Postby BroncoRaider » Tue Sep 11, 2018 8:44 pm
Looks good Adam. Great birthday gift!
BroncoRaider
Postby phyler » Thu Jul 18, 2019 1:39 pm
Yikes, almost a year since getting anything up here. Not sure if this is my birthday gift come 2 months early but came home from a business trip to this on the hood of my Bronco.Image
CCB Admin
Postby EBsaver » Thu Jul 18, 2019 10:22 pm
phyler wrote:Yikes, almost a year since getting anything up here. Not sure if this is my birthday gift come 2 months early but came home from a business trip to this on the hood of my Bronco.Image
Dude , that’s AWESOME!! Especially since I was born in Boulder ‘76
Do you think the DMV will allow you to use it?
EBsaver
Postby phyler » Fri Jul 19, 2019 6:19 am
I too was born in 76 but my bronco is a 75 so it's the best of both worlds. [emoji16]
There is a way to use them but I'll probably just make them wall art.
CCB Admin
Postby landshark » Fri Jul 19, 2019 4:15 pm
You can run any plates for the year of your bronco or other vehicle as long as the plate has the year stamped or printed on it. You have to carry the actual plates with you. You have to fill out a form and record it with the dmv or license place. It’s free to do so
Postby phyler » Sun Jul 21, 2019 3:38 pm
landshark wrote:Image
I'll look into it. It does have the correct year for mine so that would be cool to run these.
CCB Admin
Postby rt9 » Sun Aug 04, 2019 9:17 am
Just got mine last week.
I renewed my collector plates which I now keep in the glove box with their registration.
There is a form on the state website you can download for "Date of Manufacture" plates and either sent back in via mail or take it to DMV, 1881 Pierce St., Lakewood, CO - there is no cost for the alternate registration and it only took about 20 minutes when I went in.
rt9
Images: 11
Postby phyler » Sun Aug 04, 2019 9:24 am
rt9 wrote:Just got mine last week.
Sweet. Probably will do that then. Thanks!
CCB Admin
Postby rt9 » Sun Aug 04, 2019 9:28 am
Here's the form.
rt9
Images: 11
Postby phyler » Sun Sep 08, 2019 4:00 pm
Been a while since I posted any progress pics. Been a busy summer and life keeps getting crazier. For journal purposes, in the past month, I quit my job and opened my own business with a business partner. Still doing the same thing I did before but hoping to make some money for myself instead of making other people rich (have been doing that for the past 12 years, helped build enough business that one owner sold the company for over $20 million and didn't share a dime).
Anyways, been working on the interior and the drivers side. Hoping to have the passenger side done by end of September and be driving it. Maybe if soccer schedules work out, I'll drive it to the Platte River Grill for the meetup!
Interior (all shot with a single stage paint):
Drivers side (base and clear that was made up to better match than the single stage):
After lots of sanding, base coat:
Then clear:
Using my LED shop light to throw some better light on it:
It's not perfect but I'm pretty happy with it. I've learned a ton and have a lot of respect for the guys who do this for a living.
CCB Admin
Postby D&D72 » Sun Sep 08, 2019 6:42 pm
Wow Adam, that’s looking great!
D&D72
Postby mickphatmac » Sun Sep 08, 2019 7:10 pm
Man that’s Lookin GOOD!!! thumbs up thumbs up thumbs up
