[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - Pitman Arm Taper Ream
Hi all,,
So I'm getting back to adding power steering to my Bronco. The box I purchased has a pitman arm with a straight bore hole. (different spline count than the original) Does anyone have a tapered reamer to work with the ball joint or know where I can take this to be machined? My brother is a machinist, but does not have this particular reamer.
Thanks
Rick
Tue Oct 23, 2018 5:53 pm
rt9
Re: Pitman Arm Taper Ream
Ok, so I just re-read my post. The hole on the pitman arm that needs taper reamed, is the one for the ball joint on the draglink. Sorry for any confusion.
