It is currently Sat Sep 28, 2024 4:16 pm
[ 9 posts ] |
Chevy blower motor issues
B.O.B.
I did the swap and had to put a spacer between the motor and the heater box to keep the cage hitting the back side. Problem is I keep popping fuses. Have the motor grounded to the dash and it is getting power from the original wiring. Is there anything I should be looking at? I also blocked off the fresh air hose from the outside and ditched the box. Anybody ever try to put a pusher fan on the outside to push more air in?
Wed Dec 05, 2018 10:19 pm |
la hi
Re: Chevy blower motor issues
GROUND, GROUND, GROUND, then a heavier wire from the power source to the heater motor!!
Thu Dec 06, 2018 8:02 am |
Mine was actually melting the solder inside the fuse, without blowing the fuse. It was an original harness & there was light rust on the contacts where the fuse snapped into the box. Cleaned up the contacts with some sandpaper and the problem was solved.
Thu Dec 06, 2018 8:36 am |
la hi
Good job!
Thu Dec 06, 2018 8:47 am |
Willem’s was/is doing the same, plan is to replace the heater blower circuit with non 50 yo parts.
Thu Dec 06, 2018 11:50 am |
Fri Dec 07, 2018 7:38 pm |
B.O.B.
Where is exactly would I put this breaker? Before the resistor, after, before the fuse?
Sat Dec 08, 2018 5:17 pm |
Sat Dec 08, 2018 7:43 pm |
B.O.B.
Found the issue. My ECU came loose and was hitting the resistor causing it to short out. Luckily nothing was damaged. Working great now just need to change the thermostat.
Wed Mar 06, 2019 4:02 pm |
[ 9 posts ] |
