www.ColoradoClassicBroncos.com - View topic - welding gas bottle
It is currently Thu Oct 31, 2024 11:23 pm
Reply to topic  [ 18 posts ]
 welding gas bottle
Post welding gas bottle
Looking for a bottle I can use for shielding gas, Argon/CO2 for welding. Also looking for a gauge for it as well.
In or near Norco.
Tue Jan 22, 2019 12:12 pm
Post Re: welding gas bottle
Have you called your local supplier? I understand they generally run on an exchange program, but they may have something for you to buy??
Wed Jan 23, 2019 9:19 am
I've bought all of mine off craigslist. They usually have to be filled, but the bottle purchase is about 50% off the welding shops.
Wed Jan 23, 2019 12:36 pm
I did call a couple and it's well, more expensive than I had anticipated. BUT, I suppose that I will just start saving my dimes.
Thu Jan 24, 2019 8:21 am
I know I picked my up used too, but it has been years so I don't recall what I paid for it. Buy & sell on facebook?
Thu Jan 24, 2019 10:16 am
Hey Mike,
My only suggestion is that if you buy a used one make sure its has a current hydro test, if the tank is out of the date range you may get an additional "testing" charge at the gas store.
Thu Jan 24, 2019 11:16 am
Good info! Thank you Gents!
Thu Jan 24, 2019 1:13 pm
And here I thought maybe someone was making a bowling ball mortar smokin smokin
Thu Jan 24, 2019 7:49 pm
This is a CO2 bottle they are using for a Kegerator!
Will this work!???
Thu Jan 24, 2019 10:14 pm
Straight CO2 is fine, many prefer 75% CO2 & 25% argon. Not sure how big that bottle is, looks kind of small, which means lots of trips to refill it. I used a CO2 tank from a soda machine set up.
Thu Jan 24, 2019 10:16 pm
I think it is pretty small, but is that basically all I need? I can have them put 75/25 argon/co2 in that bottle and use that regulator?
Thu Jan 24, 2019 11:20 pm
I was using 75/25 from a CO2 tank when I moved here. I tried swapping it out, but they didn't offer 75/25 in that size, so I ended up with straight CO2. I like it fine enough. Maybe a bit more spatter, but supposed to be better penetration. If I remember, the valve on the tank was different for the 75/25 mix, and there is an adapter piece available to fit between the tank & the CO2 reg. But I may be wrong, it's been about 1 year since I changed to straight CO2.
Thu Jan 24, 2019 11:28 pm
Fri Jan 25, 2019 8:27 am
Fri Jan 25, 2019 8:35 am
Do you know if I can exchange a Helium bottle for one that holds Argon/CO2?
I’m going to buy this one if you can exchange the one for the other. (The guy wants $60 bucks and it’s empty)
Sun Jan 27, 2019 1:11 pm
Sun Jan 27, 2019 1:16 pm
Thanks Adam that’s what I was hoping to hear.
Sun Jan 27, 2019 2:08 pm
Getting a large group of people together (possibly Bronco enthusiasts) to inhale all that helium almost seems like a moral obligation.
Mon Jan 28, 2019 1:18 pm
32,736,402 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
