It is currently Sat Sep 28, 2024 11:17 pm
[ 5 posts ] |
Chromoly or HD Dana 44 outer axle shafts
Looking for two Chromoly outer axle shafts for the Dana 44 - something better than stock strength, also looking for HD Ujoints
Thu Mar 14, 2019 9:36 am |
RJLougee
Re: Chromoly or HD Dana 44 outer axle shafts
297 or 260 sized U-joints? Joe
Sat Mar 16, 2019 6:01 pm |
Believe I need 760
Mon Mar 18, 2019 12:24 am |
RJLougee
760 and 297 are the same size, just different part numbers. The 5-760x is the newer version, forged if I remember correctly, non-greasable version. 5-297 is the same dimensions, but less strong and greasable. This all the newer D44 sizes, full with '76+ D44, etc... Same as modern Jeep D44s.
The 5-260 is the original EB D30 and D44 stock size U-joints.
If you're planning to install the actual Spicer 5-760x U-joints, I wouldn't bother with aftermarket cromo shafts, you'll tear up the axle ears as the U-joint tears itself apart.
I can help if you just want some stock HP D44 outer stubs, no joy for cromo or HD U-joints. HTH, Joe
Fri Mar 22, 2019 6:53 pm |
Appreciate the offer, I think I have it covered!
Sun Mar 24, 2019 11:42 am |
[ 5 posts ] |
