cw72 wrote:Well, here’s something. I have a thought this may be the cause.
Digger wrote:cw72 wrote:Well, here’s something. I have a thought this may be the cause.
The return is dumping into the pickup sump? Crazy.
cw72 wrote:Digger wrote:cw72 wrote:Well, here’s something. I have a thought this may be the cause.
I have to assume it’s by design for very low fuel levels, but I think moving the return away from that will solve it. May do a different type of pickup.
https://classicbroncos.com/forums/showt ... p?t=274708
This may be beneficial in more than one way.
Jesus_man wrote:So the return was dumping into the small diamond shaped pickup area? Can you hook it a bit of rope and pull it enough to clear it out of there? I mean, if you have to cut the tank to fix that, then you're asking for trouble in the explosion dept.
Jesus_man wrote:Sure, but you have to weld it back up...
The neighbor to my folks lost his life doing this.
I was thinking a cable type cutter, but you hate to introduce metal shavings into the system.
Do you know who made the tank?
ZOSO wrote:I'm running a hydramat. Seems to work great. My tank was like yours and I ordered a hat/pickup from nwmp and went intank. drained my tank and filled with water a few times to flush it out. filled with water and drilled the hole with a hole saw. Drained the tank and wiped it all out. Put in a new walbro pump and hydramat. No issues left now.
