This is an incredible summary! Thank you for taking the time to write that up! I'll follow this step by step. Maybe I'll document it with some photos and video and add to it.Digger wrote:The generic procedure for 4x4 transmission removal goes something like this:
1. Remove driveshafts, clutch linkage (or hydraulic lines), speedo cable, transfercase linkage and transmission shifter
2. Remove exhaust (if necessary, most are in the way somehow)
3. Support transmission and remove crossmember (use transmission jack)
4. Slightly lower transmission and remove the 6 bellhousing bolts.
5. Wiggle transmission and t-case free. Keep the transmission as square to the engine as possible to prevent input shaft damage.
6. Carefully lower transmission out of the way. WARNING, these things are heavy and awkward when you are laying on your back. They have a tendency to shift at the wrong time. Strap it down to the transmission jack.
7. With transmission out of the way, remove clutch, resurface flywheel or replace, replace throwout and pilot bearings. (DO NOT reuse throwout or pilot bearings. Murphy guarantees they will fail soon after and you will be pulling the trans again). Removal of the pilot bearing may require a small slide hammer.
8. Install new flywheel, torquing crank bolts to mfg's torque spec.
9. Install new clutch, using supplied alignment tool before tightening.
10. Lift and position transmission for installation. You want to make sure the bellhousing faces are parallel top-to-bottom and side-to-side. If it is not lined up, it will not go. PRO-TIP: put the transmission in the highest gear. As you bring the transmission and engine together, the input splines will connect and if they are not lined up, they will not go. By hand wiggle the transmission (or t-case) output back and forth as you push forward on the transmission. You will feel it when the two slip together. Ideally, you should be able to put the bellhousing faces together all the way. Sometimes there might be a small gap (1/8") that you can close by tightening the bell housing bolts. DO NOT try to draw them together will longer bolts. If you cant get them close enough to use the factory bolts, something is hanging up.
11. With the transmission back in place, reverse steps 4-1.
B.O.B. wrote:Hit me up though if you need help. Sounds like I’m not too far from you.
phyler wrote:A good transmission jack is worth it's weight for this.
I've used that Harbor Freight jack before and it was fine for the light transfer case I was dropping. I wouldn't use it for the Bronco combo if I could avoid it. It uses a ratchet to raise and lower versus being hydrologic.laffycaffi wrote:phyler wrote:A good transmission jack is worth it's weight for this.
In your opinion, what's the best transmission jack out there? Looks like Harbor Freight has one that is cheap but has good reviews: https://www.harborfreight.com/automotiv ... 61232.html
Also is the replacement clutch I can order through my local auto parts store, or should I defer instead to Wild Horses, et al...
The local parts store quoted about $100 and had two styles, "Heavy duty" and something else. Wild Horses has me feeling more confident but their stock replacement is $170.
Jesus_man wrote:Luk is a good brand. You wouldn't have any issues there.
but patience and finesse will prevail.
Kinder wrote:Yes and no, those bolts hold the pressure plate in place, the clutch is sandwiched between the pressure plate and fly wheel so it’ll drop out when you pull the pressure plate. Do yourself a favor and just loosen all the bolts first, then take them all out except for the top most bolt, you can then pull the clutch down and then the last bolt to let the pressure plate down.
Questions for you.
Are you going to get the flywheel resurfaced/machined or are you replacing it?
Do you have the kit that includes the installation tool that centers the clutch when you attempt to reinstall everything?
Also there is a pilot bushing (old style) or bearing (new style) installed in the end of crank that is press fit, or at least should be unless it’s in bad shape and you should have a new one in the kit. Removing that isn’t too bad with the proper technique. Search online for a video and you’ll see some options for removing it, usually involving wet newspaper or heavy axle grease. Of course there is a puller that could likely be rented as well, your call if you want to use the garage mechanic method or more pro level.
laffycaffi wrote:Funny, I found a video that showed a guy using a mix of grease and bread to get the pilot bushing out.
The clutch and pressure plate is already off.
Back to the pilot bushing/bearing... that's located behind the flywheel, correct? I do plan on replacing it. I don't know if I have a bushing or a bearing. But it's surely stock. So should I assume it's a bushing? Should I replace it with a bearing, or does it work like that?
Removing the fly wheel is just a matter of removing the bolts, correct? I haven't tried yet, but I hear the wheel wants to turn while trying to remove those bolts. Any tips/tricks there?
Thanks again!
Mark
That's what I was thinking. My reverse lights have never worked.cpldavis37 wrote:I really have no idea, but that could be a reverse light or something. I have a C4 and I dont remember any electrical going to it. Mt reverse lights and neutral safety switch and now in my Shifter. Of course yours is different being a 3 spd.
laffycaffi wrote:Couple more questions...
1. After the transmission was out, I found this broken wire. Any ideas what this is? Concerning?
2. Based off the other photos here, it's obvious that I've got some leaking. Any idea what seal or gaskets should be replaced?
Thanks again for all the help
Sent from my SM-N950U using Tapatalk
