www.ColoradoClassicBroncos.com - View topic - Electric fuel pump wiring
It is currently Sat Sep 28, 2024 1:06 pm
Reply to topic  [ 11 posts ]
Post Electric fuel pump wiring
Where is the best place to “wire” my fuel pump?
I will be mounting it on the frame rail very close to my rear main tank and grounding it there as well.
Where is the best and EASIEST place to run the hot wire?
Sun May 26, 2019 12:24 pm
Post Re: Electric fuel pump wiring
So can I run the hot wire from the pump up to the “I” terminal of the starter solenoid? Will that give me constant power in the on position?
Mon May 27, 2019 11:30 am
That is a fine pick up point for the wiring. I'd fuse it, or use a relay depending on the amps of the pump. You might consider a fuel shut off switch that is used in case of an accident. A heavy impact will trip the switch and shut off your fuel pump. They are used on lots of factory fuel injection systems. I'm sure you can find one in most salvage yards.
https://www.cjponyparts.com/ford-fuel-p ... F5EALw_wcB
Mon May 27, 2019 11:50 am
Awesome! Thanks Gunni!
Mon May 27, 2019 12:54 pm
I may have one in my box o stuff. I'll check but, they are cheap at a junk yard and you can cut off the connector too.
Tue May 28, 2019 9:27 pm
You may want to measure voltage off that post. For some reason I believe it only provides about 9volts as it's running.
Wed May 29, 2019 6:28 am
Wed May 29, 2019 9:46 am
That is correct you don't want to use that I terminal. come from ignition hot to a relay to carry the load of the fuel pump.
Wed May 29, 2019 10:33 am
Profile WWW
Wed May 29, 2019 11:19 am
Sat Jun 01, 2019 9:34 am
Sat Jun 01, 2019 4:57 pm
32,364,312 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
