Electric fuel pump wiring
Postby mickphatmac » Sun May 26, 2019 11:24 am
Where is the best place to “wire” my fuel pump?
I will be mounting it on the frame rail very close to my rear main tank and grounding it there as well.
Where is the best and EASIEST place to run the hot wire?
Re: Electric fuel pump wiring
Postby mickphatmac » Mon May 27, 2019 10:30 am
So can I run the hot wire from the pump up to the “I” terminal of the starter solenoid? Will that give me constant power in the on position?
Postby Gunnibronco » Mon May 27, 2019 10:50 am
That is a fine pick up point for the wiring. I'd fuse it, or use a relay depending on the amps of the pump. You might consider a fuel shut off switch that is used in case of an accident. A heavy impact will trip the switch and shut off your fuel pump. They are used on lots of factory fuel injection systems. I'm sure you can find one in most salvage yards.
https://www.cjponyparts.com/ford-fuel-p ... F5EALw_wcB
Postby mickphatmac » Mon May 27, 2019 11:54 am
Awesome! Thanks Gunni!
Postby D&D72 » Tue May 28, 2019 8:27 pm
I may have one in my box o stuff. I'll check but, they are cheap at a junk yard and you can cut off the connector too.
D&D72
Postby ZOSO » Wed May 29, 2019 5:28 am
You may want to measure voltage off that post. For some reason I believe it only provides about 9volts as it's running.
Postby mickphatmac » Wed May 29, 2019 8:46 am
ZOSO wrote:You may want to measure voltage off that post. For some reason I believe it only provides about 9volts as it's running.
Interesting...Come to think of it, I may remember reading something about 12v at startup to fire the engine but drops to lower voltage for coil?
Postby horseplay » Wed May 29, 2019 9:33 am
That is correct you don't want to use that I terminal. come from ignition hot to a relay to carry the load of the fuel pump.
horseplay
Postby mickphatmac » Wed May 29, 2019 10:19 am
horseplay wrote:That is correct you don't want to use that I terminal. come from ignition hot to a relay to carry the load of the fuel pump.
I was just trying to make it a little easier by bypassing the ignition switch which the installation fought me like a SOB!!!!!!!
Postby Gunnibronco » Sat Jun 01, 2019 8:34 am
Sorry for the bad advice. I guess I haven't even worked on or driven a Bronco in so long I can't remember how things work. I don't remember what is hooked up to the starter solenoid anymore.
Postby mickphatmac » Sat Jun 01, 2019 3:57 pm
No worries!!!
I know the RIGHT way... I was just looking for an easy way!
