Colorado75bronc wrote:Nice man, looks good
Justin wrote:Quick bump for your build thread. Here are your long-overdue shock towers! I'll let you know when they're en route. I'm stoked to see them all fabbed in, and I'm excited to see the progress of your build as you get the rest of your shiny new parts installed.
Gunnibronco wrote:Almost forgot. I got a set of 15x8 steel rims and cleaned them up & painted them in some single stage gray. I mixed it by eye to closely "match" the bumpers of Audi's. Decided that I didn't want black, definitely didn't want white. Someday I'd like to repaint the top a light gray and get rid of all the white. The 8" rims helped with how far my tires stick out with the wide axles. It still sprays the windshield & side windows with mud and I'm going to install a set of Silverbacks, I find seeing outside of the truck to be helpfull.
I've also removed & replaced my 15+ yr old JD coils and springs. I got a set of 3.5" WH rears and a 5.5" set of front coils. At first it sat a little rear end high, but it settled nice and level. The front coils bow out badly to the f/w axles, I'll be installing a set of wide upper coil buckets soon to fix that.
