HD Brake Master Cylinder
Postby mickphatmac » Sun Aug 04, 2019 5:59 pm
I’m going to be installing a power brake booster in the ‘73. I intend on keeping all four corners drum brakes.(for now) Is there a master cylinder out there that will fit and work better than the stock one? I think I remember someone saying they use one off of an F250? I think it has 2 hold down clips instead of just one?
What year and specifics would really help... or if the regular one works just fine, that would be helpful to know as well !
This is what I think it looks like ?
Re: HD Brake Master Cylinder
Postby phyler » Sun Aug 04, 2019 6:26 pm
mickphatmac wrote:I’m going to be installing a power brake booster in the ‘73. I intend on keeping all four corners drum brakes.(for now) Is there a master cylinder out there that will fit and work better than the stock one? I think I remember someone saying they use one off of an F250? I think it has 2 hold down clips instead of just one?
Lots of folks go with the 78 f250 camper special when going to disc fronts. That said, for drums, I think the standard master does really well. I even think it's doing great for disc/drum using the Ford swap with Thunderbird calipers.
CCB Admin
Postby TOOLMAN » Mon Aug 05, 2019 6:20 am
I think that one is a 'Corvette' master. I think I have a never been used F250 Camper Special M/C laying around somewhere.
TOOLMAN
Postby mickphatmac » Mon Aug 05, 2019 9:15 am
TOOLMAN wrote:I think that one is a 'Corvette' master. I think I have a never been used F250 Camper Special M/C laying around somewhere.
Thanks Toolman... any Idea how much you want for it and do you know if it's for a Drum/Drum set up?
Postby TOOLMAN » Mon Aug 05, 2019 9:37 am
I don't see why you couldn't use it. Maybe someone can chime in that knows for sure. I bought it because it has the larger bore/piston than the F150/bronco counterpart when I was still rocking manual brakes. Only problem was, the outlets are on the passenger side so I couldn't use it. How does $20 sound?
TOOLMAN
Postby mickphatmac » Mon Aug 05, 2019 9:51 am
Sounds like an amazing deal! DEAL!
You around this weekend?
PM me your address and when is a good time to come pick it up?
Thanks again Jason!
Postby Gunnibronco » Mon Aug 05, 2019 9:21 pm
TOOLMAN wrote:I don't see why you couldn't use it. Maybe someone can chime in that knows for sure. I bought it because it has the larger bore/piston than the F150/bronco counterpart when I was still rocking manual brakes. Only problem was, the outlets are on the passenger side so I couldn't use it. How does $20 sound?
Drum brake master cylinders keep more pressure in the brake lines after you release the pedal.
You can add a residual pressure valve if you are using a m/c for a disk brake set up. Probably add one to the front of the F250 m/c, I'm assuming it is from a front disk/rear drum truck.
https://www.summitracing.com/parts/wil- ... /overview/
Postby mickphatmac » Mon Aug 05, 2019 10:04 pm
Good info!!!
Going to get one with a 1 1/8” bore...
