Never done body work before
Postby rt9 » Mon Jul 15, 2019 6:24 pm
I want to remove this rust before it starts to eat the steel. Any suggestions?
I'm not ready for a complete paint job yet, but figure I better do something here soon.
Thanks
Rick
rt9
Images: 11
Re: Never done body work before
Postby Gunnibronco » Fri Jul 19, 2019 10:51 pm
I don't think there is much you can do that won't look bad or require paint work. You really need to strip it down and hit it with some rust converter, or cut out the bad stuff and start over. I wish I had a better suggestion.
Postby Stubborn3 » Sun Jul 21, 2019 3:02 pm
Yeah do it now or you’ll be in my shoes dude. It doesn’t get better, easier, or cheaper.
Stubborn3
Postby rt9 » Sun Jul 21, 2019 6:44 pm
Gunnibronco wrote:I don't think there is much you can do that won't look bad or require paint work. You really need to strip it down and hit it with some rust converter, or cut out the bad stuff and start over. I wish I had a better suggestion.
So the plan is to clean up the area around the rusted seams and remove the old seam sealer. I found a cool little dremel wheel that gets right after it!
I also purchased a portable media blaster at HF that I'll try out too. Should clean out the groove nicely.
Once the gap is open and cleaned up, I'm going to use a spray bottle with encapsulation fluid or some POR-15 on a brush.
Epoxy prime, New seam seal, and Paint.
Wish me luck!!!
RT
rt9
Images: 11
Postby Gunnibronco » Sun Jul 21, 2019 8:22 pm
I think you are doing it the best way possible without stripping the tub. What I see in your pics is what I imagined as best case scenario.
Postby rt9 » Sun Jul 21, 2019 8:24 pm
Thanks. Hope all is well.
rt9
Images: 11
Postby Gunnibronco » Sun Jul 21, 2019 8:28 pm
Thanks things are good. Still settling into a new life here. Trying like hell to get my shop done. It's very hard to find electricians and plumbers willing to take the work. When I do they want $2000+ per day in labor. So I'm doing most of it myself.
Postby EBsaver » Sun Jul 21, 2019 9:55 pm
“I also purchased a portable media blaster at HF that I'll try out too.”
RT[/quote]
FOLLOWING!!
I wanna know how that media blaster works out for ya? How messy? I need a way to sand nooks & crannies
A buddy just told me you can use corn kernels as media blaster, but he’s not a body guy so who knows.
I just cut out my old rear quarter and before welding new metal to old, I’d like to clean it up first & hit it with rust treatment. The issue I’m having so far is rust treatment seems to impede the welding process...so, how to get the treatment between two panels?!!
I’m ready to install new b-pillars & quarters...last thing I want is to do all this work & see rimust come through the paint in 5 years.
EBsaver
Postby EBsaver » Sun Jul 21, 2019 10:00 pm
Temp’d in place
EBsaver
Postby Gunnibronco » Sun Jul 21, 2019 10:33 pm
EBsaver wrote:“I also purchased a portable media blaster at HF that I'll try out too.”
RT
I just cut out my old rear quarter and before welding new metal to old, I’d like to clean it up first & hit it with rust treatment. The issue I’m having so far is rust treatment seems to impede the welding process...so, how to get the treatment between two panels?!![/quote]
There are lots of media choices for blasting. I'm not an expert, I'd read up and start with the least aggressive product and work up to whatever works.
I've never tried to weld through the rust treatments, but I know it leaves a coating. I had to sand it off to get body filler to stick.
Postby rt9 » Thu Jul 25, 2019 6:49 pm
Mini bead blaster is "ehh"... Ok I guess but not real good getting in the groove. Makes a mess. Lol
Sprayed encapsulation fluid on and brushed it in the gaps. Another coat in 20 minutes.
Overall there wasn't much rust inside, luckily.
Primer on 48 hours after final cure.ImageImageImage
rt9
Images: 11
Postby Jesus_man » Fri Jul 26, 2019 4:32 am
Glad you caught it. I've acquired my broncos when it was too late for this sort of method. It's just great to see you save a bronco body!!
Postby rt9 » Fri Jul 26, 2019 4:36 am
Jesus_man wrote:Glad you caught it. I've acquired my broncos when it was too late for this sort of method. It's just great to see you save a bronco body!!
Thanks. I'm trying.
The hard part is where do you stop? This could easily morph into a major project.
rt9
Images: 11
Postby Justin » Sat Jul 27, 2019 9:57 am
Bronco creep is real. There's a reason mine spends so much time on jackstands. Besides fishing, that is.
Postby rt9 » Mon Oct 07, 2019 6:05 pm
So, Adam inspired me to finish mine. It's still a 15 footer but no more rust seams!
Notice the custom electrical contacts for my brake light bucket. Juicefruit?ImageImage
rt9
Images: 11
Postby Strike2 » Mon Oct 07, 2019 7:36 pm
Nice work it looks great!
Strike2
Postby phyler » Mon Oct 07, 2019 8:12 pm
Definitely looks good!
CCB Admin
