EGR delete on 96 EFI
Postby Strike2 » Fri Jan 31, 2020 2:09 pm
I just saw a posting on CB about plugging the EGR port on the intake, I didn't do anything to mine (but only have 30+min of brake in time)
Is this something I should be concerned about ? ?
Strike2
Re: EGR delete on 96 EFI
Postby Moab Mike » Fri Jan 31, 2020 7:29 pm
Yes, If you are not using EGR you should plug the port. I believe I used a 3/4" or 1" NPT Pipe tap which creates enough thread to thread a brass pipe plug with an allen head into either the intake or the head. I chose the head because I already had the engine in the bay already and wanted it to be easy to clean out.
Moab Mike
Postby Strike2 » Fri Jan 31, 2020 7:59 pm
Dang that’s not good news, looks like I’ll add that to my list!
Thanks for the reply Moab Mike
Strike2
Postby D&D72 » Sat Feb 01, 2020 9:50 am
You can put it in the upper half too without issue since you lower appears to be installed.
D&D72
Postby Strike2 » Sat Feb 01, 2020 7:42 pm
D&D72 wrote:You can put it in the upper half too without issue since you lower appears to be installed.
Well that’s good news !
I was not looking forward to taping the lower intake and dealing with the metal shaving.
Thanks for letting me know D&D72 thumbs up
Strike2
Postby mickphatmac » Sun Feb 02, 2020 7:39 am
I was looking into this last year when I was considering doing EFI and found this ...fel pro 1250 intake gasket set has parts that block the EGR crossover at the cylinder head/intake manifold gasket. This is the best spot to block off the EGR gasses so that they do not enter the intake manifold and heat it up.
Just install the gasket and no tapping drilling etc.
Postby landshark » Sun Feb 02, 2020 9:15 pm
I tapped mine without pulling the lower intake off the engine, You can carefully put a rag or something that won't tear apart in the hole, tap it carefully and then vacuum it out. It worked great for mine and had no issues or metal shavings
Postby Strike2 » Wed Feb 05, 2020 11:49 am
landshark wrote:I tapped mine without pulling the lower intake off the engine, You can carefully put a rag or something that won't tear apart in the hole, tap it carefully and then vacuum it out. It worked great for mine and had no issues or metal shavings
Chris,
Did you drill the hole or just tap it? it looks like a 1/2-14 NPT tap will work without drilling. Do you remember what size tap you used.
Strike2
Postby Gunnibronco » Wed Feb 05, 2020 12:57 pm
I just looked back at what I did. I tapped the upper intake with a 7/8-9 tap. I don't know what the lower intake would use.
Postby Strike2 » Wed Feb 05, 2020 2:28 pm
Gunnibronco wrote:I just looked back at what I did. I tapped the upper intake with a 7/8-9 tap. I don't know what the lower intake would use.
Thanks Gunnibronco,
Would that have been a 7/8-9 NC Course Thread?
Strike2
Postby Gunnibronco » Wed Feb 05, 2020 2:32 pm
Yes, then I cut a bolt off, threaded it in. It was loose and I was wanted to make sure it didn't move, so I think I staked it in place. Maybe some red lock-tite would have worked. I forget exactly what I did.
Postby Strike2 » Wed Feb 05, 2020 2:46 pm
Gunnibronco wrote:Yes, then I cut a bolt off, threaded it in. It was loose and I was wanted to make sure it didn't move, so I think I staked it in place. Maybe some red lock-tite would have worked. I forget exactly what I did.
Thanks I'll check both the 7/8-9 and the 1/2-14
I like the 1/2-14 just because of the taper cut but I also prefer taping the upper due to metal shavings. Darn real world life decision lol
Strike2
Postby landshark » Mon Feb 10, 2020 12:53 pm
Sorry just getting back. I am not sure but want to say 1/2 NPT? I could be wrong -
Postby Strike2 » Mon Feb 10, 2020 3:14 pm
NP Chris,
I'm pretty sure a 1/2-14 NPT tap would work on the lower, but on the upper there just isn't enough depth to work. And since the lower is already installed and it running I didn't feel like taking the "risking" this late in the build. I use a 7/8-9 tap like Gunnibronco recommended on the upper and it work great!
Strike2
