I just saw a posting on CB about plugging the EGR port on the intake, I didn't do anything to mine (but only have 30+min of brake in time)
Is this something I should be concerned about ? ?
D&D72 wrote:You can put it in the upper half too without issue since you lower appears to be installed.
landshark wrote:I tapped mine without pulling the lower intake off the engine, You can carefully put a rag or something that won't tear apart in the hole, tap it carefully and then vacuum it out. It worked great for mine and had no issues or metal shavings
Gunnibronco wrote:I just looked back at what I did. I tapped the upper intake with a 7/8-9 tap. I don't know what the lower intake would use.
Gunnibronco wrote:Yes, then I cut a bolt off, threaded it in. It was loose and I was wanted to make sure it didn't move, so I think I staked it in place. Maybe some red lock-tite would have worked. I forget exactly what I did.
