3rd Brake Light with White Reverse/Backup light
Postby mickphatmac » Mon Mar 02, 2020 12:57 pm
I copied a picture of one of Phils diagrams on classic Broncos.com I hope he doesn’t mind.
Mine is a 68 but I think the coloring on the wires is basically the same.
Can someone tell me what color(s) to run to the (3rd) red brake light and which color(s) to run to the (3rd) back up light?
Passenger
Green
Brown
Blk/Red
Drivers
Yellow
Brown
Blk/Red
License plate bulb
Brown
The third brake light basically has one wire for the RED light with one ground wire
And basically the same for the reverse light, one wire with a ground as well
It’s listed as cargo lamp but I want to hook it up as my reverse light!
Re: 3rd Brake Light with White Reverse/Backup light
Postby phyler » Mon Mar 02, 2020 4:47 pm
Brown is marker/taillights. Just hooked mine up yesterday. Yellow is stop.
I used the wiring diagram at seabiscuit68.tripod.com.
Adam
CCB Admin
Postby mickphatmac » Mon Mar 02, 2020 6:01 pm
So if I want the Tail light to act like a marker light and a brake light then I need to wire both the Brown and Yellow wires to it?
And I’m assuming the black and red is the back up light wire?
Postby phyler » Mon Mar 02, 2020 6:04 pm
mickphatmac wrote:So if I want the Tail light to act like a marker light and a brake light then I need to wire both the Brown and Yellow wires to it?
Yes to both.
http://seabiscuit68.tripod.com/images/75-77_28-32_color.gif shows the Reverse lights.
CCB Admin
Postby Mitche11 » Mon Mar 02, 2020 9:01 pm
I wired up a similar light mounted on the top back part of my roll bar. I ended up running a separate brake light from the switch back to the 3rd brake light because it kept blinking with the turn signal from one side or the other. Backup was as easy as pulling from the wires in the tail-light, and running hot wires from each brake light wasn’t going to work. FYI.
72 Bronco Sport, 5.8 EFI, NV3550
Mitche11
Postby mickphatmac » Tue Mar 03, 2020 6:58 am
Thank you Gentleman!
Postby Viperwolf1 » Tue Mar 03, 2020 8:40 am
Black-red is reverse light.
If you don't want the 3rd brake light to flash with turn signals you need to run a new wire directly from the brake light switch (before it gets to the turn signal switch).
Postby mickphatmac » Tue Mar 03, 2020 11:50 am
Viperwolf1 wrote:Black-red is reverse light.
You are correct, I don't want it to blink!!!
Thank You!!
