Eck wrote:Work was slow this afternoon so I pulled the lower intake and re-sealed it hoping it fixes the oil leak I had. Fingers crossed that was the culprit and I got enough right stuff on it this time.
Is this a sneak peek at the 2021 Baby Bronco?Viperwolf1 wrote:I just thought I would accidently share this pic.
Eck wrote:Where is the glitter?
Eck wrote:Is this a sneak peek at the 2021 Baby Bronco?Viperwolf1 wrote:I just thought I would accidently share this pic.
Hopefully the Bronco will never be in a position that other people will see that!
Evolkid wrote:Wrapped up my steering wheel with a Superior wrap.
I used this one “Truckline”rt9 wrote:Evolkid wrote:Wrapped up my steering wheel with a Superior wrap.
Looks Super!!! Do you happen to have the size and product number? I've been looking at these for a while and might just go ahead now.
Thanks - Rick
ZOSO wrote:For 3 months Ive been battling an EMI issue with my stereo. I have been back and forth with the manufacturer and we went as far as replacing the head unit. I am at a complete loss as what to do next. Its an issue with the ignition system/transmission.
landshark wrote:ZOSO wrote:For 3 months Ive been battling an EMI issue with my stereo. I have been back and forth with the manufacturer and we went as far as replacing the head unit. I am at a complete loss as what to do next. Its an issue with the ignition system/transmission.
Assume you have tried a ground loop? also have you tried to move the stereo ground to somewhere near or on the frame?
Digger wrote:ZOSO wrote:For 3 months Ive been battling an EMI issue with my stereo. I have been back and forth with the manufacturer and we went as far as replacing the head unit. I am at a complete loss as what to do next. Its an issue with the ignition system/transmission.
I have some experience with noise and signal conditioning. I can give you a hand with that when this COVID thing settles down. Is the head unit integral or is it a separate head unit and amp?
Have you tried a noise suppressor?
ZOSO wrote:landshark wrote:ZOSO wrote:For 3 months Ive been battling an EMI issue with my stereo. I have been back and forth with the manufacturer and we went as far as replacing the head unit. I am at a complete loss as what to do next. Its an issue with the ignition system/transmission.
Yes tried it all. I have an idea whats going on but its too long to type out what I have tried.
Digger wrote:
I'll assume that means you tried one of these?
I can throw an O- scope on it later. Either we can track down the noise and deal with it or build a custom filter to knock down the noise.
