So on the new Blue Print motor, I am using a quart of oil every 200-250 miles. Motor has 2500 miles on it. Rings should be seated,right? Called Blue Print they said to check plugs and run a compression test. All but one plug is oil fowled . Compression test is 150-155. They said to replace intake gaskets.
Pulled intake and gaskets show signs of oil getting past into runners on both sides. I have never seen this before. I used the Fel-Pro gaskets that came with the motor. Short of putting a sealant around each port anyone have a suggestion on a fix?
Intake is a new Weiand.
Don't know about you all but miss the breakfasts!!
