Register •
FAQ
• Login
It is currently Wed Jun 05, 2024 11:54 am
[ 6 posts ] |
Strike2
Bronco Short Pitman Arm
I have a 75 OEM steering box w/pitman arm, and the arm is just hitting the tie rod bar. So before trimming the bar I'm looking for a shorter pitman arm. Does anyone have the "shorter" version they would like to sell ? or know of a replacement part number or if their is junkyard vehicle pitman that is compatible.
Thanks Steve
Thu Jul 16, 2020 12:39 pm |
Re: Bronco Short Pitman Arm
I don't know the measurements of the longer vs shorter arms but here are a couple options I had saved along the way. https://classicbroncos.com/forums/showt ... p?t=278927https://www.wfoconcepts.com/Products/Vi ... =3360,4427Maybe one of these could work.
Thu Jul 16, 2020 3:29 pm |
Strike2
Thanks Gunnibronco! Those are 2 solid leads that I didn’t have before, I’ll hit up the JY tomorrow and see if 1of the 5 Astro vans has what I’m looking for if not I’ll order the one from WFO
Thu Jul 16, 2020 4:18 pm |
6" center to center, 8" overall length. Perfectly flat. I'll trade you arms.
Thu Jul 16, 2020 5:43 pm |
Strike2
That should work perfect Viperwolf1, I’m acually heading up to the Greeley DMV on Tuesday morning for a 9:30 appointment I’ll text you on Monday and see if you’ll be around .
Thu Jul 16, 2020 8:16 pm |
Good information. I would like to swap a shorter pitman arm onto mine.
Fri Jul 17, 2020 7:40 pm |
[ 6 posts ] |
