Bronco Short Pitman Arm
Postby Strike2 » Thu Jul 16, 2020 11:39 am
I have a 75 OEM steering box w/pitman arm, and the arm is just hitting the tie rod bar. So before trimming the bar I'm looking for a shorter pitman arm. Does anyone have the "shorter" version they would like to sell ? or know of a replacement part number or if their is junkyard vehicle pitman that is compatible.
Thanks
Steve
Strike2
Re: Bronco Short Pitman Arm
Postby Gunnibronco » Thu Jul 16, 2020 2:29 pm
I don't know the measurements of the longer vs shorter arms but here are a couple options I had saved along the way.
https://classicbroncos.com/forums/showt ... p?t=278927
https://www.wfoconcepts.com/Products/Vi ... =3360,4427
Maybe one of these could work.
Postby Strike2 » Thu Jul 16, 2020 3:18 pm
Thanks Gunnibronco!
Those are 2 solid leads that I didn’t have before, I’ll hit up the JY tomorrow and see if 1of the 5 Astro vans has what I’m looking for if not I’ll order the one from WFO
Strike2
Postby Viperwolf1 » Thu Jul 16, 2020 4:43 pm
6" center to center, 8" overall length. Perfectly flat. I'll trade you arms.Image
Postby Strike2 » Thu Jul 16, 2020 7:16 pm
That should work perfect Viperwolf1, I’m acually heading up to the Greeley DMV on Tuesday morning for a 9:30 appointment I’ll text you on Monday and see if you’ll be around .
Strike2
Postby Digger » Fri Jul 17, 2020 6:40 pm
Good information. I would like to swap a shorter pitman arm onto mine.
Return to Bronco Parts Wanted
