$125 - Duffs Power brake booster and bracket
Post by mickphatmac »
This is used but in very great condition. I was told that the brake booster itself has a little bit wider diameter in between the front 2 bolts made for disc/disc brake conversion?
IΓÇÖm sure you can use it with disc/drum or even drum/drum as long as you get the correct master cylinder for it.
la hi
Re: $125 - Duffs Power brake booster and bracket
Post by la hi »
Thanks i will check out the possibility.
***SOLD***
