It is currently Wed Nov 20, 2024 10:31 am
[ 13 posts ] |
Mr. Lav
Joined: Sun Apr 17, 2011 11:33 am Posts: 200 Location: yoder, colorado
metal fuel lines
have a quick question on fuel lines. What is everyone running for fuel lines? Getting ready to replace and have seen people running metal looking for the size of line and where to pick up some at. I'm running the mustang EFI, so pressure and return Thanks Alex
Tue Feb 26, 2019 11:46 am |
B.O.B.
Re: metal fuel lines
I ran 3/8 stainless for both. Got it from Summit. Some say you can run a smaller return but it was just easier for me to run the same.
Tue Feb 26, 2019 12:00 pm |
Strike2
I'm running a 96 Explorer EFI/fuel pump and PTFE hose from summit, although running hard lines is much cheaper. https://www.summitracing.com/parts/sum-220985
Tue Feb 26, 2019 1:13 pm |
cpldavis37
I bought mine from BC Bronco's.
Tue Feb 26, 2019 1:41 pm |
Bought a roll of 3/8" steel tubing from napa.
Tue Feb 26, 2019 6:50 pm |
3/8" steel hardline for pressure side, 5/16" steel hardline for return.
I used poly for the soft lines () and SAE J2044 quick disconnects () to make the jump from hardlines to filters, tank and engine.
Tue Feb 26, 2019 8:10 pm |
Wed Feb 27, 2019 10:23 am |
Wed Feb 27, 2019 6:01 pm |
Great thanks. We had a tool kit at the first body shop I worked at and made my brake lines for my full width axles. I can see getting a lot of use out of that.
Wed Feb 27, 2019 6:44 pm |
Mr. Lav
ok so which is better steel or poly (I was told to stay away from poly) cause if poly will work I have the kit with gun at work, with the steel lines looking at the fittings they look like they go together like air brake lines. thanks Alex
Thu Feb 28, 2019 10:53 am |
You want to use steel lines (stainless) as much as possible. They make up the majority of the run between the tank and engine, and attach to the frame rails. But you need to make connections between the rail and the tank and the rail and the engine. That's where poly or rubber comes in. Any time there is motion between two components, you need a soft line. I chose poly over braided rubber lines because it used OEM style connectors, it's tough and not very expensive. The OE's spend a lot of time proving something out, so if they are using push-to-connects and poly line, its good enough for my 50 yr old Bronco. Another ancillary benefit I had was being able to use off-the-shelf fuel filters from the parts store. (shown in the picture above) AN fittings are also good-to-go. They have a well established history in military and industrial applications. The least preferred option is hose barbs and hose clamps. They work okay, but hose clamp quality has gone way down with the flood of foreign produced parts, which can lead to leaks. I've started collecting hose clamps at the Pick-N-Pull because parts store stuff is pure garbage. Disassembly after time can be difficult and make necessitate cutting the line. Push-to-connects and AN fittings rarely leak, require minimum effort to install and are reusable. That's my sales pitch.
Thu Feb 28, 2019 11:21 am |
Mr. Lav
Thanks everyone for the info, I'm going to use stainless and then poly for the soft line part of it.
Thu Feb 28, 2019 11:55 am |
I like Digger's logic. I'm using steel line with rubber (not AN) hose. The EFI hose is expensive and very hard to disassemble from the barbs without cutting it off. I'll be doing it with the fittings & nylon next time for sure.
Thu Feb 28, 2019 8:11 pm |
[ 13 posts ] |
