It is currently Fri Nov 22, 2024 2:35 pm
[ 5 posts ] |
CL ad: 351W and AOD builders- 80.00 (COS)
Thu Oct 23, 2014 7:39 pm |
Colorado75bronc
Re: CL ad: 351W and AOD builders- 80.00 (COS)
The aod is junk, the 4wd tail housing is useful, not sure if the tail shaft is the same as a 4r70w or if the 4r70w shaft has updates for flow/ sealing or strength, but the 351 is easily worth that
Thu Oct 23, 2014 8:45 pm |
Worth putting it in your reserve
Thu Oct 23, 2014 9:42 pm |
Like corey said. the early AOD's were junk. if you want an AOD you need to find an 88 or later. Early ones had serious oiling issues.
Fri Oct 24, 2014 6:59 am |
REH
Joined: Fri Oct 07, 2011 12:28 pm Posts: 56 Location: Cortez
84 should be a c-6
Fri Oct 24, 2014 9:19 am |
[ 5 posts ] |
