'79 Bronco full width high pinion Dana 44 housing...free!!
79 bronco high pinion Dana 44. I bought a complete diff to take the disc brakes off of for my brother in laws bronco. Therefore the axle is missing everything from the knuckles outward. I can include the knuckles that come off of his early bronco axle if desired. They have 5 month old moog ball joints in them but you will need everything else. I did not crack the diff cover to check the condition of the gears but i was told it was running and driving before i bought it so i assume they are ok. This would be a great way to get full width and high pinion for really cheap as long as you don't mind swapping your brakes on to this housing.
