www.ColoradoClassicBroncos.com - View topic - 66 Bronco Project
It is currently Thu Nov 21, 2024 8:54 am
Reply to topic  [ 206 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 66 Bronco Project
Post Re: 66 Bronco Project
Well I took my first drive down the road in it with the 4.10 gears in it..she handles well but wow I think shes geared way too low..I mean maybe if I hauled it to the trail but with those gears shes not street worthy..I thought at first my trani wasnt shifting into high gear..its a c4 with a hurst star shifter..seemed like more of a drag vehicle though..but I put it in drive and I could feel all all the gears kick in..heck I even went through and hit each one 1,2 then D and I could feel the last gear kick in from second but to drive it the rmps were skyrocketing and I wasnt moving that fast..before when I had the 3.54s in it I could cruise 70 no problem but at 70 now I would peg the rmps..anybody have any ideas?maybe the transfercase is geared real low?Im kicking around throwing my 3.54 gears back in but want some input before I do..
Im your huckleberry
Wed Aug 24, 2011 3:21 pm
With 35's and 4.10's at 55mph you should be around 2600-2800rpm. If not then something isnt right.
Wed Aug 24, 2011 3:31 pm
Im your huckleberry
Wed Aug 24, 2011 3:34 pm
Your t-case in high is going to be 1:1 and won't affect your final drive ratio. I assume a C4 does not have an OD? Are you sure you're not on low range??
Using this site: http://www.rocky-road.com/calculator.html
with 35's you should be running around 75mph at 3000rpms.
Grab your gps and hit the highway again and give us some hard numbers as to mph and rpms...can work backwards from there.
If I leave my tranny in 4th, with my setup, I could probably cruise 65 comfortably.
Also, you won't be happy with anything less than 4.10's on the trail, unless you stick to 3 and under rated trails. Anything more technical and you'll quickly realize low gearing is king. So the time comes to decide what you really want to do with the rig or...time for an Atlas where you can run your 3.73's, but still have a great crawl ratio for the trail...
Wed Aug 24, 2011 3:36 pm
Wed Aug 24, 2011 3:48 pm
Im your huckleberry
Wed Aug 24, 2011 3:56 pm
Wed Aug 24, 2011 3:59 pm
Im your huckleberry
Wed Aug 24, 2011 4:12 pm
all the way forward to the dash is low range. pull it all the way back. thats 4 high.
Wed Aug 24, 2011 4:33 pm
Yeah, 50mph and screaming is low range. You'll be a bit happier in high range. You'll get about 40% more speed for the same rpms in high.
Wed Aug 24, 2011 4:45 pm
That is one nice ride!
74 Ranger
65 Fastback
Wed Aug 24, 2011 5:58 pm
Ok now I feel like a complete retard u guys were right I'm use to this new age crap and thought hi was straight up..damn well it works now..lol guess I should have drove her a little more before I started building here..lol anyway yes it runs so much better now that the tcase is in the right gear I'm probly gonna hear about this one for a while huh? Oh well thanks for the help guys as usual that's why I love this club!
Im your huckleberry
Wed Aug 24, 2011 6:16 pm
So far it's you and Chad in a club.........
Wed Aug 24, 2011 6:24 pm
Thanks Chaos took for taking some of the heat away from me. lmao
I know you have went through hell getting your truck together and the rear end has been one of the headaches - cool when it is something little like that.
Wed Aug 24, 2011 6:28 pm
Im your huckleberry
Wed Aug 24, 2011 7:01 pm
Chaos - you're killing me... lol, I'm glad you got it sorted out, I bet it was screaming.
Wed Aug 24, 2011 7:09 pm
Wed Aug 24, 2011 7:24 pm
Middle row, left knob...
Need me to get you one?? oops
LOL! Glad it was something simple as well. BTDT and got the t-shirt!
Really tho, finding 2-low takes a LOT of practice! But finding 2-High and 4-low are the priorities!
Wed Aug 24, 2011 7:50 pm
Wow that transfer case pattern was totally different then what I thought guess I know now..and yeah she was taking off like a rocket poor thing..blow the cobwebs out of that sob! All I have left now is install the front bumper and winch and build the rear bumper and gas can holder then buy a spare..and its good to go planning a trip to eagle rock either the first or second week of sept if anyone wants to play..
Im your huckleberry
Wed Aug 24, 2011 9:00 pm
I would love to hit the trails with you. First weekend I am out for sure. Second weekend, my wife works Saturday morning, so that means I have my son with me. He's not old enough to hit the trails yet. But, I may be able to swing a baby sitter.
Thu Aug 25, 2011 7:51 am
Im your huckleberry
Thu Aug 25, 2011 9:59 am
Yeah, I am out during the week for sure...
Thu Aug 25, 2011 11:40 am
Well ran into another problem ill have to fix before I do anything drove the Bronco 15 miles into town to get some new plugs and wires and on the way back it started over heating real bad so I'm sure ill have to replace the water pump or thermostat or the dang radiator..all the luck
Im your huckleberry
Thu Aug 25, 2011 4:16 pm
Sorry to hear that. Hope you can get it up to snuff quickly. I am sure you will. You have made a lot of progress the last couple months!
Thu Aug 25, 2011 4:30 pm
I'm sure u guys have all replaced ur radiators With aliminum ones I saw one on ebay that was a 3 row and came with an electric fan is anyone running one of these or is anyone running electric fans and do they work good or at least better then this stock crap I don't want to have to mess with overheating issues seems every vehicle I get has them
Im your huckleberry
Thu Aug 25, 2011 4:32 pm
Well I installed a new thermostat in it and still overheated I'm sure the radiator missing a fan shroud has a lot to do with it...guess the next step is to order that amunimum radiator with electric fan and see if that helps if not then order a new waterpump..
Im your huckleberry
Thu Sep 01, 2011 11:58 am
Got my aluminum radiator and my electric fan in and installed today kicked on when the motor warmed up correctly so I guess ill take it for a spin tomorrow and see if I solved my problem I hope so..then ill go ahead and install my front bumper and winch tomorrow still waiting for my rear bumper to be delivered then ill install it and hopefully be ready to wheel..
Im your huckleberry
Thu Sep 08, 2011 9:08 pm
radiator and bumper installed along with winch
Im your huckleberry
Sat Sep 10, 2011 5:08 pm
me likey
I really like the looks of that flat black finish on the bumper, it goes great with the blue
burnout brother
Sat Sep 10, 2011 5:17 pm
Sweet. Jayson
74, MONEY EATER
Sat Sep 10, 2011 7:09 pm
32,912,524 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
