ZOSO wrote:Pull one that's the correct length and one that's loose. Measure them. If the same I'd say you have some lifters that are collapsed. Did you soak the new lifters in a bucket of oil? Pump them up? Prime the oil system before starting?
ZOSO wrote:well did it get any better?
Rox Crusher wrote:So, The Bronco Master (not you Shawn) figured out precisely what was needed.........which meant we had to go with push rods that were 60 thoughsanths longer and use a 30 thousandths shim to get the effective length we needed.
It now purrs like a roller rocker kitten.
Just gotta get the exhaust leak at the passenger side collector sealed up. This is the same place we had trouble on Phil's.
Thank you Phil !
Moab Mike wrote:Rox Crusher wrote:So, The Bronco Master (not you Shawn) figured out precisely what was needed.........which meant we had to go with push rods that were 60 thoughsanths longer and use a 30 thousandths shim to get the effective length we needed.
Thank you Phil !
Hmmm, I recall someone else mentioning pushrods.
Thank you Phil !
landshark wrote:Moab Mike wrote:Rox Crusher wrote:So, The Bronco Master (not you Shawn) figured out precisely what was needed.........which meant we had to go with push rods that were 60 thoughsanths longer and use a 30 thousandths shim to get the effective length we needed.
Thank you Phil !
Was it Sean?
Eck wrote:Dude, your hood is missing...
So you going to Moab?!
Moab Mike wrote:Very nice but I was expecting a 100' burnout!
akaFrankCastle wrote:Which exhaust is that?
