www.ColoradoClassicBroncos.com - View topic - Digger's '69 Build Thread
It is currently Sun Nov 24, 2024 4:10 am
Reply to topic  [ 477 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 16  Next
Post Re: New Member 69
Build Thread:
Mon Jun 15, 2015 7:42 pm
You just need taller tires. poke
Mon Jun 15, 2015 10:05 pm
Build Thread:
Mon Jun 15, 2015 10:24 pm
My plan from the beginning was to make the Bronco our family adventure rig. Part of that plan involves towing our small popup camper, for which I needed a hitch. Weighing a lot of options, I settled on the Tom's receiver hitch. It wasn't the cheapest, but it gets the job done and saves me more fabrication time.
by , on Flickr
The only things I don't like about the Tom's hitch is the way the receiver tube is welded in the middle of the cross tube and lack of any actual Class III certification.
I had to re-drill the holes in my gas tank brackets and slot the frame holes slightly rearward to clear the 23 gal fuel tank. (not a Tom's tank)
by , on Flickr
I also had to notch the PO's rear bumper to clear the hitch, but it fits well. The new bumper will clear without issue.
by , on Flickr
Build Thread:
Tue Jul 21, 2015 9:00 pm
A bronco with a trailer brings tears of joy to my eyes!
Tue Jul 21, 2015 9:04 pm
I also needed some side mirrors since mine were removed and 'glassed over by the PO.
I bought some 1stGen Ranger/BII mirrors from Dorman. They gave the Bronco a little bit more modern look.
I had to contour them slightly to match the curve of the door.
by , on Flickr
New Rivnuts in the door.
by , on Flickr
by , on Flickr
by , on Flickr
Build Thread:
Now for the big job!
I have been unable to take the kids anywhere due to lack of rear seat. I ordered a Tom's fold-n-tumble, but refused to install it until I had proper roll over protection. The Bronco came with a simple roll bar tied to the floor. I didn't trust it much. I needed a full six-point cage and wanted to do something a little different with the front legs. My plan was to build a cage modeled after the Rock Hard Sport cages used on Jeep JKs to free up space in the foot box and tie the cage to the firewall to add rigidity to the body. I also will tie the cage through the floor to the frame for strength.
Using what I modeled before in CAD I hashed out an idea and polished it up it bit using computer analysis.
The first part was laying out the legs and making sure they would fit between the dash and inner wall of the tub.
by , on Flickr
by , on Flickr
by , on Flickr
Build Thread:
Tue Jul 21, 2015 9:23 pm
I had a whole weekend without the family, so I took 2 extra days off to bang out this project. This was Saturday morning at 6:30am.
by , on Flickr
Time to start yanking parts!
by , on Flickr
by , on Flickr
by , on Flickr
Build Thread:
Tue Jul 21, 2015 9:27 pm
I like knowing where my tube came from:
by , on Flickr
A side view of the front legs.
by , on Flickr
Bending some tube. I was going to build this in two pieces, but decided to try the whole thing in one shot.
by , on Flickr
Mocking up the main hoop and side hoops took the longest since it was laying the foundation for the rest of the work.
by , on Flickr
Figuring out the front interface.
by , on Flickr
by , on Flickr
End of day 1 (T=15hrs)
by , on Flickr
Build Thread:
Tue Jul 21, 2015 9:32 pm
I spent Sunday tacking together pieces and adding more body tie-in points to each leg. I also started laying out the rear halo and diagonal supports.
by , on Flickr
Since I can't put diagonal bracing in the B-pillar hoop, I came up with a plan to form a large "X" from the back corners to the front corners to triangulate the cage.
Using CAD to determine tube lengths and cope angles, the pieces fit together nicely.
by , on Flickr
by , on Flickr
Day two ended with all the tubes installed and tacked into place. (T=30hrs)
by , on Flickr
Build Thread:
Tue Jul 21, 2015 9:38 pm
I woke up Monday and took one more picture in the daylight
by , on Flickr
Monday I needed to add all the necessary brackets for 3-point seatbelts and windshield supports along with corner gussets.
I build out triangulated brackets to hold the windshield, taking care to make sure the frame was parallel with the doors.
by , on Flickr
by , on Flickr
With everything in place, my neighbor helped me pull the cage to finish welding the tubes and brackets together.
by , on Flickr
Here you can see the longitudinal and lateral braces for the front legs. I tied into the strongest points on the body. Now the cage ties the rear of the body to the front and should add much rigidity to the truck. Even without these brackets, the front legs are pinned in by the dash and door supports and the fit is tight.
by , on Flickr
Day 3 (T=42hrs)
Build Thread:
Tue Jul 21, 2015 9:47 pm
Tuesday I got to work early to beat the rain. It was time for some paint!
by , on Flickr
by , on Flickr
by , on Flickr
After waiting a few hours, time to install!
by , on Flickr
The welds came out pretty good. flipoff
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
I didn't take many pictures, but I got the Tom's Fold-n-Tumble seat installed along with the 3-point seat belts.
by , on Flickr
by , on Flickr
The fit with the soft top came out perfect. I maximized the room inside without interfering with anything important.
by , on Flickr
by , on Flickr
by , on Flickr
Total time = 54 hrs.
Build Thread:
Tue Jul 21, 2015 9:54 pm
Dang. That is nice! Love the front legs.
Tue Jul 21, 2015 10:02 pm
Build Thread:
Wed Jul 22, 2015 12:05 am
Love the cage. when are you tying it into the frame?
Wed Jul 22, 2015 6:53 am
thumbs up thumbs up thumbs up
Wed Jul 22, 2015 7:03 am
Very nicely done! I really like the look. kids will enjoy the first ride!!
Wed Jul 22, 2015 7:05 am
Very nice.
Wed Jul 22, 2015 8:16 am
soooo when can I drop mine off to get a cage built/installed? Looks great!
Wed Jul 22, 2015 8:57 am
Build Thread:
Wed Jul 22, 2015 3:52 pm
More build, more pictures. Rear bumper this time:
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
Build Thread:
Sun Aug 23, 2015 8:46 pm
Testing out fit with the camper. She's a bit tight, but still has enough clearance. I was ready to replace the lift jack if necessary. Even went through some dips without issue.
by , on Flickr
by , on Flickr
Build Thread:
Sun Aug 23, 2015 9:00 pm
And for my last-minute, midnight-buzzer-beater job, I threw together a storage box to lock up the tools. Not Fort Knox, but will deter the opportunist.
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
Build Thread:
Sun Aug 23, 2015 9:03 pm
Looks great! I like the box!
Sun Aug 23, 2015 10:22 pm
box looks cool.... think Ive seen similar somewhere before icon biggin thumbs up
Mon Aug 24, 2015 7:31 am
Build Thread:
Mon Aug 24, 2015 8:33 pm
What size plate did you use on the front of the cage?
Tue Aug 25, 2015 9:24 pm
Build Thread:
Wed Aug 26, 2015 9:07 am
Build Thread:
Mon Nov 09, 2015 8:37 pm
Much better. Looks great!
Mon Nov 09, 2015 8:39 pm
32,990,603 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
