It is currently Thu Nov 21, 2024 11:59 am
69 Dudes-- Just the beginning
Re: 69 Dudes-- Just the beginning
Nice,
Glad that worked. I've had that link saved for a long time.
How much body lift do you have?
Sun Feb 21, 2016 7:39 pm |
Sun Feb 21, 2016 8:30 pm |
Removed the long tube headers that had originally come with the Bronco. Will be installing shorties from BH. Pretty big difference. The passenger side does touch the inner fender so I'll have to figure that out. Might first try to loosen the body mounts and slide the body over 1/4" or so. If not, I'll have to cut and move the inner fender over a tad...
Sat Mar 05, 2016 6:18 pm |
Are those BC Broncos?
Mine are way too close to the transmission. I couldn't even get the ZF in with the headers on. Not even close.
Sat Mar 05, 2016 8:39 pm |
Sat Mar 05, 2016 8:46 pm |
Damn. Trade ya? LOL.
Don't push the body, you'll screw up your hood/fender gaps.
Adjust the inner fender.
Sat Mar 05, 2016 9:01 pm |
Sat Mar 05, 2016 9:17 pm |
If you just push the front of the truck (2 body mounts under radiator support) it will only push the front over. It will make your hood opening diamond, or parallelogram shape, not a square or rectangle. So your square hood won't fit in the opening with even gaps.
You'd have to loosen all the bodymounts, and push the whole body over. I don't know that its worth it.
Just bend the inner fender.
Sat Mar 05, 2016 9:36 pm |
Sat Mar 05, 2016 9:51 pm |
It would probably work. just labor intensive.
Sat Mar 05, 2016 9:54 pm |
Don't move the body, the BH headers touching the inner fender skirt is common. Pop a couple of the spot welds and make a small bend at the seam, then re-attach.
Sun Mar 06, 2016 10:23 am |
I'm with Kinder. Modify the fenderwell. I had to do the same thing on mine.
Sun Mar 06, 2016 10:44 am |
Mon Mar 07, 2016 6:18 pm |
Trans crossmember looks great!
Mon Mar 07, 2016 8:03 pm |
D&D72
That crossmember is damn sexy. That Justin is a swell fella...... Nice work, both of you.
Mon Mar 07, 2016 9:04 pm |
looks great!
Mon Mar 07, 2016 9:43 pm |
Good job.
Tue Mar 08, 2016 1:48 am |
You guys did a great job! You will like having a nearly flat belly.
Tue Mar 08, 2016 2:42 am |
Tue Mar 08, 2016 9:45 am |
Super nice.
Tue Mar 08, 2016 1:02 pm |
D&D72
Tue Mar 08, 2016 7:10 pm |
Mon Mar 14, 2016 5:08 pm |
Looks great. Have you chosen a muffler? Running a cat?
Tue Mar 15, 2016 2:35 am |
TOOLMAN
Looking very good!
Tue Mar 15, 2016 8:04 am |
Nice work Eck! I like the inner fender mod. It always sucks to start out on one project and get side-tracked with another, but you took that inner fender and made it your B*!$H! Keep it up
Tue Mar 15, 2016 8:09 am |
Tue Mar 15, 2016 8:44 am |
There is no real brand. It's a clone of the sample they sent to the manufacturer.
Tue Mar 15, 2016 10:57 am |
Do you know who the exhaust manufacturer is? It's one of the nicest I've seen.
Tue Mar 15, 2016 7:57 pm |
Tue Mar 15, 2016 8:39 pm |
I'm currently in a holding pattern for finishing the front axle. Yesterday I was able to get the radius arms mounted to the axle with bushings and they ended up very even on the first shot (thanks Tim for the help). I decided to start running electrical and install the ARB components. I'm going to fab a small box to mount on the roll cage between the cage and vent window. Should hide everything nicely and give me easy access to the switches. This is probably temporary until I decide what I want to do...
Tue Mar 22, 2016 7:20 pm |
