www.ColoradoClassicBroncos.com - View topic - Justin's retroactive build thread
It is currently Thu Nov 21, 2024 3:31 pm
Reply to topic  [ 544 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 19  Next
Post Re: Justin's retroactive build thread
Fri Sep 25, 2015 8:40 pm
Mmmmm, stuff.
Mon Sep 28, 2015 10:06 pm
nice!
Mon Sep 28, 2015 10:25 pm
Can't wait to see it climbing rocks and putting all your hard work to proper use!!
I also want to know what you think of those trep's!
Tue Sep 29, 2015 12:42 am
So, are you going to be trail leader on our first snow bashing run next spring ?
#strongkicktofinish
Tue Oct 20, 2015 5:02 am
Lol! Might be. Still picking away at it daily. Drivers front corner is almost done. Took a little while to figure out the needed inner fender mods.
Tue Oct 20, 2015 7:03 am
Thought I'd post up a couple of quick pics of what I've been up to. I've gone through about 4 versions of this panel before getting one that was the best compromise of battery space and tire clearance. I'm pretty happy with how it came out. I've got about 1/4" of clearance between the tire and the fender at full stuff and full lock and there are no sharp edges to cut the tire if things flex enough to rub.
Tue Oct 20, 2015 9:47 pm
You have left enough room for the battery in that locations still? I like it. I can't wait to see how it performs in the field!
Wed Oct 21, 2015 5:36 am
Nice work. Its amazing how quickly all the extra space disappears.
Wed Oct 21, 2015 7:20 am
No joke. It turns out that big tires are big. The battery will still fit, but I'll need to change to an optima specific box (should arrive from RuffStuff today) and move it over a little. I'm going to weld in a second brace on the other side to support a second battery. At some point I'd like move the batteries under the driver's seat so that the weight is lower and farther back, but it's not going to make a big enough difference that i'm willing to invest the time now.
Wed Oct 21, 2015 10:18 am
Passenger's front side is done. It needs at least one softer spring and I have to put in the vented wheelwell panel, but the actual work on this side is finished. Not too much left on the driver's side, so in 170 months the front end should be done.
Sat Oct 24, 2015 10:49 pm
I was just wondering how many months in we were... This thing better print money by the time you're done.
Sat Oct 24, 2015 11:16 pm
I think we're 3,287 months in. And it better be putting out by the time I'm done.
Sat Oct 24, 2015 11:22 pm
Looks good, and I agree on both accounts as to what it should be capable of!
Sun Oct 25, 2015 3:29 pm
The point of no return...
Tue Nov 03, 2015 12:30 am
you might as well start the frame stretch "while your at it"
icon biggin
Tue Nov 03, 2015 1:46 am
I do have the frame extension pieces already cut! Haha
Tue Nov 03, 2015 6:58 am
so you are just gonna 4 link the rear now?
Tue Nov 03, 2015 6:18 pm
Linking the rear is definitely on the list, but I'm not sure I'm going to take it on at this stage in the game, mostly because it would mean another $600 in joints and brackets. Getting the EFI done will reap bigger rewards in general driveability, and I don't want to have to engineer sway bar installation yet. The shocks I'm going to run are 14" threaded body Fox's, so it's getting set up so that all I have to do is cut out the leafs and install the links when the time to do it comes. Everything is going to get aligned so that there is clearance to just throw springs on the shocks and hit the road.
Tue Nov 03, 2015 11:21 pm
Am hoping to get the front end done this weekend and have it sitting on the tires instead of jack stands. Please send vibes to the universe for me to get garage time.
Sat Nov 14, 2015 10:43 am
Build Thread:
Sat Nov 14, 2015 11:04 am
That's hysterical. I need to figure out how to set an avatar as a gift.
Sat Nov 14, 2015 10:50 pm
Well, it's sitting entirely under it's own weight for the first time in over a year. Nothing broke off immediately, so I'm taking that as a good sign. I think I nailed the spring rates, too.
Thu Nov 26, 2015 12:20 am
Congrats! Get that thing running soon!
Thu Nov 26, 2015 10:34 am
Congrats! I can't wait to see this thing driving.
Build Thread:
Thu Nov 26, 2015 11:03 am
Thanks! I might need to plumb the rear brakes and drive it around a little before I tear into the rear.
Thu Nov 26, 2015 12:02 pm
I'm sure that will really boost your motivation levels, I know when I couldn't drive mine I was not very motivated to do as much with it
Fri Nov 27, 2015 11:20 pm
Turns out I'm not going to drive it before tearing into the rear end. Took advantage of the warmer temps to open up the garage door and keep the burning undercoat from making my house smell like burning condom. Freed up a heck of a lot of room for suspension parts and big tires.
Sat Nov 28, 2015 5:03 pm
Wow, and I thought I knew how to cut up a tub, good job!
Sat Nov 28, 2015 10:55 pm
Thanks! I think you still win. Definitely if measured by total linear feet cut.
Sat Nov 28, 2015 11:04 pm
32,923,672 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
