Rox Crusher wrote:Tank back in, new gas added to cleaned tank, runs great again.
Well, that didn't last long (less than 50 miles actually)
ZOSO wrote:You have more fuel pump issues than everyone here combined. Maybe a pink jeep is less problematic.......
Whats it doing now?
Whats it doing now?
ZOSO wrote:Yep. If the regulator gets "stuck open" it is letting too much fuel back to the tank and your not getting full pressure at the rails.
ZOSO wrote:Does this do it just idling or do you have to be driving?
ZOSO wrote:need to remote mount the fuel pressure gauge and possibly get a wideband o2 in there to see what it's doing. What are the actual symptoms? If it's just in that short window in only that gear under that particular load it makes me think it's more electrical. Do you have an oiled air filter on it? Have you pulled the MAF and cleaned the wire?
ZOSO wrote:another thing is have you pulled the plugs? I wonder if something happened and on is out of gap.
ZOSO wrote:Another thing to check it voltage. What gauge wire do you have running to the pump?
Is it ok when cold and get worse after driving for a while?
Have you thrown a timing light on it lately?
Rox Crusher wrote:Do you happen to know the proper gap ? The guy at orielly's told .054 which sounds excessive.
