It is currently Tue Dec 17, 2024 7:50 pm
First Time Bronco Owner - 1969 Bronco
pgilbeau
Re: First Time Bronco Owner - 1969 Bronco
Thanks, think I have it figured out. Parts are on the way and will just have the A/C Bracket and stuff as extras. Not sure what I want to do for a fan yet, on my Ranger I didn't like dealing with the fan clutch so I went electric, may do the same here. Got to start working on this instead of shopping.
Tue Jan 19, 2016 11:29 am |
pgilbeau
If all goes well I will have my donor truck for full widths this weekend, looks like I am going to change things up and get rid of the PO front suspension set up. Going to get back to figuring out how to go full width and keep the coil overs.
Tue Feb 16, 2016 11:55 am |
I don't know why you couldn't do that. Just a matter of adding the proper bracketry to the full width axles.
Tue Feb 16, 2016 12:47 pm |
pgilbeau
Tue Feb 16, 2016 12:54 pm |
If you have 5"-6" of uptravel from static ride height, you will be fine.
What is the total travel of your coilovers?
Tue Feb 16, 2016 1:30 pm |
You're welcome to swing by and take a look at my setup. I'm running about 6" of uptravel and have the track bar rubbing the oil pan at full compression.
Tue Feb 16, 2016 2:08 pm |
pgilbeau
I will probably have to take you up on that sooner or later.
Thu Feb 25, 2016 8:58 pm |
pgilbeau
Made some small progress this past weekend. The old steering box is out and I got most of the old bracket cut out. Mocked up the new box with the new bracket and stock pitman arm, the drag link angle is looking better now. Need to finish cleaning up the inner part of the frame, get a new drag link, and a new lower steering column. I think the lower steering column may be part of the problem I had, there is only about 1/3 of the splines on the coupler.
Wed Apr 13, 2016 5:59 pm |
pgilbeau
Got my drag link cut and sleeved since I plan on doing an axle swap down the road. Been doing some small things while I was waiting on the drag link and I should have everything to get the front end back together at this point.
Sat May 07, 2016 3:31 pm |
pgilbeau
Made some progress today and the steering is back together, was actually able to pull out of the garage and drive around. Got everything back together and the new drag link angle is looking much better with the 4x4x2 box and stock pitman arm.
Thu May 19, 2016 10:45 pm |
Those angles look great!! Time to get it all dirty!
Fri May 20, 2016 1:40 am |
Nice improvement! Glad you are sorting through the PO problems.
Fri May 20, 2016 7:25 am |
pgilbeau
Fri May 20, 2016 9:28 am |
pgilbeau
Made some small progress today and got the wipers working. For some reason the PO had them set up so one went the right way and the other went up, much better now. Now to move onto my next project, hydroboost. After finally driving the Bronco some and not liking the brakes I decided to skip the vacuum boost and go straight to hydroboost. Got the Wild Horses kit so I could get it done quick instead of piecing stuff together.
Thu Jun 02, 2016 10:05 pm |
You'll love hydro boost brakes !
Fri Jun 03, 2016 5:02 am |
pgilbeau
Started the hydroboost conversion today and have run into an issue already. I need to figure out what to do with the wires that run to the proportioning valve, I am replacing the existing one with one from Wild Horses. The Wild Horses valve is a one wire set up vs the stock 2 wire. Do I just splice the one into the two pink wires or ? I already know I have some work to do since I found a lovely melted mess under the electrical tape.
Sat Jun 11, 2016 11:29 am |
Yes, just splice them all together.
Sat Jun 11, 2016 12:33 pm |
pgilbeau
Sat Jun 11, 2016 9:07 pm |
pgilbeau
Looks like today is 4 months since I have posted anything to my build thread, full time college has been killing me. Got a ton of projects I intend to get going, need to work off the mountain of parts that have accumulated in my garage and get back on the road. Going to try and keep track of it all here in the thread. Here is the list:
1. Change P/S pump to dual return - DONE 2. Finish hydroboost - DONE 3. Install steering column, lower shaft, steering wheel, etc. - DONE 4. Install new seats and seat belts - DONE 5. Install winch - DONE 6. Cut old rear bumper off and install new - DONE 7. Axle swap to full widths (Farming out the axle build to speed things up and make sure the gears, etc. get set up right.) - DONE 8. Install new wheels/tires - DONE
The list is long but I intend to be done with these parts prior to December. Just ordered a ton of parts today: lockers, gears, axle shafts, ball joints, rebuild kits, bearing, and anything else needed to complete rebuilding/re-gearing the axles.
Tue Oct 11, 2016 9:13 pm |
pgilbeau
Still not making as much progress as I would like, got the axles taken to be rebuilt and pulled my new wheels out from where they have been buried. Hopefully this weekend I get some time to work on getting the Bronco back together.
Thu Oct 20, 2016 5:40 pm |
pgilbeau
Mon Oct 24, 2016 8:19 pm |
pgilbeau
Got an awesome text today, wheels and tires are ready to go. After letting the wheels sit in my shed the last 3 years finally going to put them to use.
Fri Oct 28, 2016 8:43 pm |
Those look sharp!
Fri Oct 28, 2016 9:05 pm |
That will look the part for sure!!
Sat Oct 29, 2016 6:06 am |
cravenbronco
Nice
Sat Oct 29, 2016 9:07 am |
pgilbeau
Thanks guys! Got them picked up and put on.
Sat Oct 29, 2016 12:35 pm |
Looking great !
Sat Oct 29, 2016 2:49 pm |
pgilbeau
Todays progress: picked up my new family cage. First and last purchase at the Bronco Hut!
Fri Nov 18, 2016 6:32 pm |
cravenbronco
Why is that ? Lol
Fri Nov 18, 2016 10:45 pm |
Fri Nov 18, 2016 10:54 pm |
