Jesus_man wrote:I've noticed the rotors hanging out inboard of the wheels a few times. I'm not a fan either, so hopefully you can get them tucked in!
Those Treps are ridiculous. It was a wrestling match until I figured out the best way to get the PVC inserts into the tires. I'll get a pic of the bouncer next time I'm there.Jesus_man wrote:Glad to see an update!! So sorry to hear about all the wrong parts etc... Seems reliability is no where to be found these days!
Everything looks sweet! I think you should keep the Treps! Just make your suspension all droop!
Thanks hopefully they are my forever axles.Strike2 wrote:Those axles are sick! I like how your build is turning out
BOBS 2 68S wrote:F&%ing Amazing
Jesus_man wrote:Yeah, that's quite a machine!! Pit crew would be a blast!!
And great to hear of your progress.
Jesus_man wrote:Looks like everything is fitting nicely! I wonder if you could add some sort of threaded rod and jam nut in your brake pedal so you could dial in the length perfectly? I don't know that one is made with opposing threads on either end?? But you could weld in a left handed nut on one end of a small pipe and a right handed on the other??
Justin wrote:That looks awesome! Following closely.
Jesus_man wrote:Great work Chad! Glad you are ok with the bender snafu!
Jesus_man wrote:Yes!! Is your top coil bucket double thickness or is that an illusion?
Jesus_man wrote:I see! Might copy your idea! I was shocked to learn the upper coil buckets I have put the center of spring a minimum of 5" from the outside surface of the frame. Stock is 3". Unless, like you, I cut them apart and move them inward, which it sounds like I may have to do. Seems like they are for putting FW axles under these rigs??
Jesus_man wrote:That's looking great Chad!! I think you should just clearcoat the axle!!
I wish there was a better way around getting more lift in the rear aside from custom springs. Shackles in the rear like that won't be in the way as much as they would in the front (think CJ, YJ), but there will be times they will be in the way.
