www.ColoradoClassicBroncos.com - View topic - Black Smoke Donkey
It is currently Thu Nov 21, 2024 8:21 am
Reply to topic  [ 587 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 20  Next
 Black Smoke Donkey
Post Re: Black Smoke Donkey
Thanks for the complements, I'm trying to improve my technique and was REALLY concentrating on making the welds correct. I hope pretty equals strong!
Thu Jun 13, 2013 9:47 am
We need to do a welding tech day. That looks great!
Thu Jun 13, 2013 9:58 am
Can you guess the change in this setup? And no it's not the addition of gaskets and if you had X-ray eyes you'd see the new intermediate shaft installed, not that either. The only person who can't play is brianut.
Wed Jun 26, 2013 7:34 pm
Also finished a major step today.... Motor mounts! They need to have the edges smoothed and I'm adding a section that'll wrap over the top of the frame, but the motor is actually mounted.
I'll shoot some close ups tomorrow morning and also try to finish 2 cross members as well.
Wed Jun 26, 2013 7:41 pm
Wed Jun 26, 2013 8:04 pm
Wed Jun 26, 2013 8:23 pm
Did you find a stronger ZF, its a different ribbing pattern on this trans. Plus its a lot cleaner.
Wed Jun 26, 2013 9:03 pm
Wed Jun 26, 2013 10:55 pm
Nice find. Pretty rare with the small block bell housing. Now you'll have to buy another Bronco to put your extra ZF into.
Wed Jun 26, 2013 11:02 pm
Thu Jun 27, 2013 8:06 am
Thu Jun 27, 2013 10:31 am
Cleanliness does count I guess, it came out of a farm truck and had over 3" of soil caked on it. It didn't have any leaks & I was able to start the truck and run it through the gears before pulling it.
Thu Jun 27, 2013 12:33 pm
Put in some cross members last night, hate them. Picked up new steel today for round 2.
Mon Jul 01, 2013 6:54 pm
Good fab day today, yanked the old cross members & put them in the scrap pile. Built two new ones out of 1x3x11ga and they turned out just right.
Trans mount runs high to the top of the frame & reuses the original bronco mounts to clear the front driveshaft & exhaust by going above them.
Transfer mount runs low and clears the front driveshaft & exhaust by going below them.
Here is a shot of them installed.
Also mocked up the intercooler.
And roughed in one set of new body mounts, these sit on the extension area. I still need to move the original set fwd and add another set for when I flip the body section that will contain my quarter doors.
And finally a shot showing what the belly clearance is going to be.
Tue Jul 02, 2013 7:11 pm
Well done and looks great! So...I would assume you are now the master at making "make shift" jigs!
Super cool!
Matt
Tue Jul 02, 2013 8:14 pm
Very nice work. What purpose will this rig serve? I'm just wondering if you should try to add bolt-on stiffeners between your two mounts if you are going to crawl this rig??
Wed Jul 03, 2013 1:37 am
Matt, if you mean an angle finder, vice & sharpie is a jig then yes I'm getting very good.
JD, I plan on wheeling it just the same as before. Are you saying to brace between the frame rails (as in additional cross members) or between the the new cross members to tie them together?
Wed Jul 03, 2013 9:38 am
Tie the new cross members together. That might keep them from collapsing should one get hung up. How far below the frame does the lowest one hang?
Wed Jul 03, 2013 10:50 am
I'd be tempted to integrate a skid plate into any bracing to help keep them from getting hung up in the first place.
Wed Jul 03, 2013 12:21 pm
JD, gotcha, the xfer cross member is the lowest, hangs down 4" below frame. Not bad really, my radius arm brackets hang down 3".
Justin, we are thinking alike, as soon as JD posted I was thinking skid plate. I'll need 2 get creative on the bracing & attachment points. May need 2 wait for phase 2.
Wed Jul 03, 2013 6:39 pm
Did some clean up work yesterday, finished the motor mounts, trimmed a few pieces that were a little close and notched the frame for the starter. Chris came by last night so we could add some tabs to his core support for a couple of pusher fans and he helped me set the drivetrain in for what should be the last time, I think I've pulled it out and put it in at least a dozen times during this part of the build.
Factory motor mount next to the one I built, the motor was in a Chevy setup so it had the lean, gone now.
Starter notch.
Motor mounts finished.
Xfer case notch.
Time to start running fluid lines & electrical, then the next big step coming up this week is to cut my '68 body in half and get it mounted.
Thu Jul 04, 2013 8:03 am
Looks great Kirk !
Fri Jul 05, 2013 7:24 am
Ready by the weekend?
Fri Jul 05, 2013 7:19 pm
At the rate you're going, you'll be ready to wheel tomorrow morning. We'll be at the Dumont Starbuck's at 9, see you there!
Fri Jul 05, 2013 10:31 pm
Love watching this thread - great pics and tons of details. Keep up the great work!
Wed Jul 10, 2013 10:34 am
Huge milestone this afternoon. The Black Smoke Donkey is Rollin' Coal! At least that's what the cool kids say.
http://www.youtube.com/watch?v=6nfRixAvOvw
Wed Jul 10, 2013 7:05 pm
Where's the sound?
Wed Jul 10, 2013 7:31 pm
I can't even get a dash built and he's firing up a diesel Bronco. Damn nice work.
Wed Jul 10, 2013 7:35 pm
Corey, I've got sound on my end, I can send you a copy if you want.
Wed Jul 10, 2013 9:13 pm
Dude! That is so cool!
Wed Jul 10, 2013 10:08 pm
32,911,769 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
