It is currently Thu Nov 21, 2024 2:33 pm
[ 20 posts ] |
jbickhart
imported from Houston
Bought and drove-home my first Bronco today. A '71. Normally, I don't consider a new toy 'mine' unless I restore it myself, but after 1291 miles, it feels like mine.
I was extremely happy about the purchase. I bought it before 'seeing' it from a CL ad..... first time I saw it in-person was at the Houston airport, 2 minutes before I started the trip home.
Discovered a few things to work on: front DS rubs the exhaust in 4WD which was annoying considering I needed 4WD for over 400 miles!!! Detroit locker with mud tires is really annoying (nearly fatal) since I needed 4WD for over 400 miles!! Zero weather stripping is really anno.... you get the idea.... it was a LONG trip.
Mon Feb 07, 2011 9:11 pm |
Re: imported from Houston
That is a great looking truck. Throw up some specs on what she's got in her when you get the chance!
Mon Feb 07, 2011 9:15 pm |
That is simply gorgeous truck. The two tone is just beautiful. Love the wheels - great looking truck. That is great that it made it home from Texas.
Mon Feb 07, 2011 9:21 pm |
Looks great! I'm jealous. Part of me really wanted to buy a Bronco from far away so that I could have a great story to tell...sounds like an adventure!
Mon Feb 07, 2011 9:31 pm |
Moab Mike
Plumbdoctor, your twin has arrived!
Mon Feb 07, 2011 10:02 pm |
Beautiful and welcome.
Tue Feb 08, 2011 7:49 am |
jbickhart
Thanks guys. It was a heck of a ride...
I can't complain too much: NV3550 with 35" and 4.11:1 so I could run 70-75 on good roads. But, I flew-in to Houston last Friday.... some said it was the worst time in 10 years to drive back, so there weren't any 'good' roads. Or, any open roads.
Full hardtop was nice, but no weatherstripping made for a cold ride. It was 13F across most of NM..... I figure it was 14F inside. I took the cooling fan off for most of the trip, but it overheated in San Antonio and in heavy traffic somewhere in New Mexico. I blocked-off 3/4 of the radiator (aluminum roasting pan from Walmart) but still had trouble getting the engine warm at highway speeds.... large Howe aluminum radiator. I'm betting there are some holes drilled in the thermostat.
Overall, I got more than expected, for once: the "stock" rebuilt engine has a mild cam, aluminum heads, holley 4 barrel, MSD, all new accessories and it will pull 5th gear at 1400rpm all day. I couldn't be happier with the tuning on the Holley. New complete Centech harness. All new steering from the wheel to wheels.
The dual stick shifter needs some work and after adding about 200' of weatherstripping it'll be my driver for a while.
Tue Feb 08, 2011 8:54 am |
airbur
Nice find!! I really like the color scheme and the matching hard top.
Tue Feb 08, 2011 9:14 am |
PonyCorral
Joined: Fri Dec 17, 2010 2:42 pm Posts: 297 Images: 0 Location: Arvada
What a great find!
_________________ 74 Ranger 65 Fastback
Tue Feb 08, 2011 9:58 am |
jbickhart
I would have never found it without a search engine that will look at Craigslist from any / all cities at the same time. www.searchtempest.comSearch string: "+bronco (1967|1968|1969|1970|1971|1972|1973|1974|1975|1976|1977)" it also searches Ebay if you wish.
Tue Feb 08, 2011 11:16 am |
That is a great tip. I will have to check that site out.
Tue Feb 08, 2011 12:06 pm |
PonyCorral
Indeed! I will also have to check that out.
Tue Feb 08, 2011 3:02 pm |
plumbdoctor
There goes my plan on painting the hard top the same color!??! Kiddin' ya a bit, Very Nice!!!
Tue Feb 08, 2011 3:50 pm |
jbickhart
The PO picked me up at the airport .... 2 minutes later I was driving away. I had already paid and had the title so there wasn't much reason to look it over. I checked the oil pressure and temp gages, made sure the brake pedal was firm and headed out.
I just looked...... Centech wiring harness and new switches everywhere. The motor is way overkill for a truck. Dart Pro 1 Aluminum 195cc heads with roller rockers. Full length Hedman ceramic coated headers, 7 qt. pan, MSD R-to-R, etc. Is it possible to look through through the pushrod hole and look for roller rockers. Gotta admit...... this is my first Ford, ever.
Tue Feb 08, 2011 4:45 pm |
Wow, that's a great way to bond with your rig. First Ford? soooo, first bronco too. Boy, you're in for a wild ride!! I think I would have stopped in at BC broncos (betting you drove right by) to get some weather stripping. http://maps.google.com/maps?oe=utf-8&cl ... 16&iwloc=AGreat looking rig tho and if she can make that trip relatively trouble free, that's quite a feat. Oh, and I wouldn't be so certain you have thermostat issues. I have a 3-core radiator (not alum) and I have trouble too. Changed the t-stat out a few times, but have just dealt with it. The alternative is worse. J.D.
Tue Feb 08, 2011 5:11 pm |
jbickhart
Jesus_man,
Yep. I've been a non-Ford guy until now and I've done quite a few restorations. I'm working on forgetting all the F-O-R-D jokes. They dont' seem to apply anyway..... I'm very impressed with my new buy.
You might be right about the thermostat. But, even with the fan removed, heater control valve shut, 10 minutes of idling and then 2 hours on the interstate at 70mph and the temp hadn't moved at all. It was 15 degrees that day. 3 hrs later, engine temp was 150.
Tue Feb 08, 2011 6:27 pm |
sounds like no t-stat installed at all.
Tue Feb 08, 2011 8:30 pm |
that thing is beautiful, nice find and welcome to the club
Tue Feb 08, 2011 8:32 pm |
rtreads
Dude thats a sweet looking truck!!
Tue Feb 08, 2011 9:53 pm |
Wed Feb 09, 2011 8:44 am |
[ 20 posts ] |
Users browsing this forum: No registered users and 10 guests |
