It is currently Mon Nov 25, 2024 10:35 am
Re: Can we do it ?
Tue May 27, 2014 5:16 am |
cpldavis37
Re: Can we do it ?
Did you get that off ebay? If so your the one who outbid me.
Tue May 27, 2014 3:59 pm |
Moab Mike
Re: Can we do it ?
There is a clean 351 sitting in a 1977 Thunderbird at the Aurora UPullndPay.
Tue May 27, 2014 4:07 pm |
Re: Can we do it ?
Tue May 27, 2014 4:38 pm |
Re: Can we do it ?
Tue May 27, 2014 4:39 pm |
Re: Can we do it ?
Any particular reason for the 1996 Bronco block? If I remember correctly all the 94+ 351w blocks are roller.
Tue May 27, 2014 5:11 pm |
Re: Can we do it ?
Tue May 27, 2014 6:08 pm |
Re: Can we do it ?
Might have been. My memory is far from perfect.
Tue May 27, 2014 6:46 pm |
cpldavis37
Re: Can we do it ?
94 and later blocks are roller ready. Lightnings and cobra rs were non - roller but are roller ready. Most f - series, Bronco, and econolines after 94 are roller motors. It is my under standing that only early 94's were non roller. Look for the f4te casting under . If you see that at least you know it's ready for a roller cam without any other modification.
Tue May 27, 2014 7:08 pm |
Re: Can we do it ?
I got my roller block from a 96 Econo. As stated, most big bodies, F series, E series, and Broncos should have the hotness you want. I'll keep my eyes peeled down here if you want me to. I found the Econo was a pretty easy pull despite the stubby nose. The dog house inside the passenger compartment made unbolting and disconnecting a snap.
Tue May 27, 2014 7:28 pm |
Re: Can we do it ?
Tue May 27, 2014 8:33 pm |
cpldavis37
Re: Can we do it ?
I am going to the yard tomorrow. I will let you know if I see anything.
Tue May 27, 2014 9:06 pm |
EFI Guy
VENDOR
Re: Can we do it ?
Tue May 27, 2014 9:19 pm |
Re: Can we do it ?
Wed May 28, 2014 4:27 am |
cpldavis37
Re: Can we do it ?
Hey Rox 5.8 roller 351 at the pull and pay on Broadway it's in a red 95 f150.
Wed May 28, 2014 1:30 pm |
Re: Can we do it ?
Wed May 28, 2014 3:07 pm |
cpldavis37
Re: Can we do it ?
250-300 without accessories
Wed May 28, 2014 3:59 pm |
EFI Guy
VENDOR
Re: Can we do it ?
$250 + $50 Core. I'd see if you can find one from a wrecked donor there. Odds are good that it was running when wrecked. If it isn't wrecked the reason it could be there is a bad motor.
I'll be there at some point this weekend, not sure which day yet, but I can probably lend a hand.
Wed May 28, 2014 8:08 pm |
kbank6
Re: Can we do it ?
150 plus 50 core up at Andersons. It will include the block, heads, intake, balancer, water pump, valve covers, dizzy, and oil pan according to the site. I got mine from a 96 F250.
Wed May 28, 2014 9:34 pm |
Re: Can we do it ?
Is the same GT40 tubular upper used for the cobra and lightening ?
Sun Jun 01, 2014 8:46 am |
Re: Can we do it ?
Sun Jun 01, 2014 11:20 am |
EFI Guy
VENDOR
Re: Can we do it ?
Sun Jun 01, 2014 12:05 pm |
Re: Can we do it ?
100% the same, no. Extremely similar in design and flow characteristics, yes. Worth the money to buy a branded Lightning/Cobra R upper over a GT40? Debatable. I haven't seen the flow numbers in awhile now. But, I don't recall there being a huge advantage. And if you were going to spend that kind of money, you might as well invest in a Trick Flow or Edelbrock system.
Sun Jun 01, 2014 2:04 pm |
Re: Can we do it ?
I'm wanting to find the lowest profile upper intake (hopefully OEM) that is well suited / matched for 351.
I think the explorer upper I already have will flow well enough and I thought I even heard that they actually flow as well as the GT40 tubular uppers.
Sun Jun 01, 2014 2:36 pm |
EFI Guy
VENDOR
Re: Can we do it ?
I suppose it depends on who ran the test that day, what they had for breakfast, and the alignment of the stars. I've seen a few tests that claim that the Explorer intakes actually flowed better. Unless you had to have the look of the Cobra or Lightning I'd just run the Explorer upper. I doubt that there would be any difference it total height.
Sun Jun 01, 2014 3:20 pm |
kbank6
Re: Can we do it ?
Sun Jun 01, 2014 9:45 pm |
Can we do it ?
I'm sure you can deck the upper and lower to get another .20 in clearance if you really want it. Lol
I'm still trying to figure out which motor mounts I will use. I've heard rumors of a Mustang convertible mount that is just slightly lower than the rest.
Sun Jun 01, 2014 10:01 pm |
Re: Can we do it ?
Just use a flat plate to rigidly mount the motor to the towers. Probably save 1" of space. That way you only need 1" of body lift.
Sun Jun 01, 2014 11:30 pm |
Re: Can we do it ?
Mon Jun 02, 2014 12:25 am |
Re: Can we do it ?
Hello all, Debbie Downer here...............
I've realized that it is highly unlikely I can meet my objectives of using a stock hood and maximum body lift of 1" so I am admitting defeat and moving on.
The silver lining is I already have a kick ass 5.0 EFI motor in there so I'm still happy !
Mon Jun 16, 2014 8:57 am |
Users browsing this forum: No registered users and 34 guests |
