www.ColoradoClassicBroncos.com - View topic - Black Smoke Donkey
It is currently Sun Nov 24, 2024 5:52 pm
Reply to topic  [ 54 posts ]  Go to page Previous  1, 2
 Black Smoke Donkey
Post Re: Black Smoke Donkey
Glad it works and there is enough movement. If I build one, it'll have a shackle at the frame end turned up with a twisty joint at the axle end. That will allow all the movement it needs, but controlled axle wrap.
Mon Mar 20, 2017 10:17 am
Mon Mar 20, 2017 10:21 am
Yeah, I'm not quite sure why leaf spring centering pins are made from fairly soft steel. I've sheered a couple off myself and had a hard time removing others which were bent like a worm!
Mon Mar 20, 2017 10:25 am
All good input, I considered building my own anti-wrap device, but picked this up second hand so I'll try it. I've broken enough leafs, centering pins and pinion seals, I need to control the axle rolling on its axis somehow. Once installed I think I'll mount a camera and watch the actual movements. I've been thinking of a way to justify a GoPro.
Mon Mar 20, 2017 11:51 am
Getting my shaft sorted!
Mon Mar 20, 2017 5:47 pm
Post Black Smoke Donkey
1st the good news, I have a rear driveshaft back in my truck. Now the bad, my driveshaft tube has a candy cane swirl. I guess it absorbed some of the dreaded 4bt torque. I'm designing my new driveshaft now. Flanged on both ends, 350 or 410 U joints throughout, 3" or so tube with greater than .120 wall and possibly chrome-moly. I wonder where my driveline weakness will be pushed to now?
Tue Mar 21, 2017 11:30 am
With just normal driving the drive shaft twisted?? This was brand new tube? Surely there was another factor in there. I know the 4BT is a torque monster, but a tube in good shape should have been able to handle normal driving.
Tue Mar 21, 2017 12:41 pm
Tue Mar 21, 2017 2:14 pm
Tue Mar 21, 2017 4:12 pm
I've put a little more thought into my driveshaft twisting, I may even do a little research, but eh winging it is good also, haha. I'm pretty sure that I don't have enough torque on tap to twist it without other factors. First is my axle wrap, it forces the diff end U joint into a binding situation and loads the tube with additional torsional forces. Second, I'm running a standard transmission vs an automatic, therefore torque is transferred more abruptly. Third is my automatic locker in the diff, BSD almost always has traction and "keeps" the driveline loaded under all driving situations.
Wed Mar 22, 2017 4:45 am
The way a 4 banger diesel make torque is different than. A v8 gasser as well. It's a series of big torque spikes rather than a set of smaller combined thumps. Think of it as one big hammer instead of a few smaller ones.
Wed Mar 22, 2017 8:59 am
Build Thread:
Wed Mar 22, 2017 9:06 am
2.5" OD and suppose to be .120 wall.
Sat Mar 25, 2017 9:45 am
Do these fenders make my bronco butt look big, haha!
Thu Apr 20, 2017 7:04 pm
Images: 11
Thu Apr 20, 2017 7:21 pm
I think your big butt trailer makes your butt look big. You're starting to look like a utilitarian highway patrol!
Thu Apr 20, 2017 7:23 pm
Fri Apr 21, 2017 5:09 am
those look great !
Fri Apr 21, 2017 6:08 am
I like it! now you just need that extra tall hood
Fri Apr 21, 2017 8:03 am
I was curious where you bought those from? They look great!
Build Thread:
Fri Apr 21, 2017 9:12 am
Looks good Kirk
Fri Apr 21, 2017 9:52 am
thumbs up
Fri Apr 21, 2017 10:57 am
Fri Apr 21, 2017 11:30 am
I really like the look of the pre-runner fenders, Looks Great !
Fri Apr 21, 2017 1:43 pm
Users browsing this forum: No registered users and 80 guests
33,009,961 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
